07-10-2010, 08:58 PM #1
Calculating the capacity of a heat pump
I generally design heat pumps using commonly available refrigeration parts.a lot of guess work has to be done.kindly suggest me how much heat could be extracted per hour using a one ton a.c. Compressor.
Eagerly waiting for a good suggestion.
Khan
07-10-2010, 09:16 PM #2
Re: Calculating the capacity of a heat pump
"Design", "guess" which is it? second I suspect, I would recommend that you go to school and study refrigeration, this will help you understand your question. Then you can ask again with all the info required to answer the question.
I have a question "how long is a piece of string"
Same question as yours
07-10-2010, 09:36 PM #3
LOL. I tried to answer this thread twice a few hours ago. Gave up as I felt that the OP needed to bring his own design calculations to the board, for checking & discussion.
15-10-2010, 06:39 AM #4
Wow, the question alone does not really suggest designing...
compressor for wind powered heat pump
By tomwol in forum Technical SpeculationsReplies: 32Last Post: 12-11-2011, 01:05 PM -
Heat pump-cooling and heating capacity and capacity of compressor
By sale in forum FundamentalsReplies: 3Last Post: 29-04-2010, 10:30 AM -
Pool Heat Pump
By elvis in forum Heat PumpsReplies: 5Last Post: 23-03-2010, 09:18 PM -
Sensible Heat Factor / capacity of Inverter split Systems at part load?
By Greengrocer in forum Technical SpeculationsReplies: 31Last Post: 09-02-2009, 04:57 PM -
swimming pool heat pump
By Andy AC in forum The Trail of TearsReplies: 8Last Post: 26-08-2007, 04:02 PM
