Results 1 to 2 of 2
07-10-2010, 09:23 AM #1
Aga Freezer Temperature Issues HELP PLEASE!!!
Hi I have an Aga freezer which is not holding temperature (-4 instead on -18). I understand that there is a retro fit available which is to add a heater mat to the rear underside of the chiller, where the defrost water is supposed to run out to the rear tray - to prevent it freezing.
Does any one know where I can order this from or if anyone is able to sort the problem - we are based near Gatwick is Sussex (RH17 7LX).
Many thanks in anticipation.
Edward 01825740015
07-10-2010, 11:04 AM #2
Re: Aga Freezer Temperature Issues HELP PLEASE!!!
Edward, I'm a little confused as to why you think the additional mat might improve overall performance-prehaps you might explain your thoughts?
At the risk of stating the obvious have you tried manually defrosting the freezer and then restarting?It would help with on-going advice.
Maytag Freezer TOO Cold (and fridge also)
By ptb626 in forum DomesticReplies: 1Last Post: 17-08-2010, 01:56 PM -
Hoover Nextra fridge freezer temperature
By gj1974 in forum DomesticReplies: 0Last Post: 29-06-2010, 02:51 PM -
LG heat pump problem
By back2space in forum Heat PumpsReplies: 132Last Post: 01-02-2009, 11:23 PM -
Wrong temperature on control panel
By swee'pea in forum Trouble ShootingReplies: 2Last Post: 14-01-2009, 09:18 AM -
Evaporating / condensing temperatures
By Contactor in forum FundamentalsReplies: 46Last Post: 22-07-2007, 11:19 PM
