Results 1 to 8 of 8
05-10-2010, 05:38 PM #1
Connection and Disconnection of Gauges
Im getting confused with the 'correct' way to connect and disconnect a set of gauges. Im not too sure wether its best to have the system running or off? Please help!
05-10-2010, 06:15 PM #2
Re: Connection and Disconnection of Gauges
hi xeomus, if you back seat the discharge valve, and with the charging line< middle< line connected to a bottle, open both gauge valves and all will equilise to the suction psi, then back seat the suction valve, to go one better , if you have the pisilities to pump down the system before you back seat the suction valve
a lot of tecs use the quick coupling on the end of the gauge lines but the gas that is trapped in the gauges usually just escapes,Last edited by sedgy; 05-10-2010 at 06:21 PM. Reason: made a balls - oops speling pistake
05-10-2010, 06:17 PM #3
Ideally the system is better not running as this reduces the pressure your exposing yourself to,
the method i prefer is to use line with ball valves
1 close high side ball valve
2 open manifold to let pressure from the high side to the low side
3 rub lines to warm refrigerant and remove as much as possible from lines
4 close low side ball valve
5 disconnect both lines
05-10-2010, 08:24 PM #4
Just to add a third option... assuming that you have ball valves or a quick connector on the high side..
Shut the high side ball valve (disconnect quick connector), open the high and low valves on the manifold to reduce the line/gauge pressures back to the lower suction pressure.
Close valves on manifold and then disconnect from the low side.Brian - Newton Abbot, Devon, UK
06-10-2010, 08:44 AM #5
06-10-2010, 10:26 PM #6
^^ Good point Frank ^^
07-10-2010, 10:47 AM #7
Do they have special manifold gauges with very small inner diameter hoses for use with systems that only holds 250g of refrigerant at most, like home refrigerator?
07-02-2011, 12:10 PM #8
Cheers Fellas,
Sorry i never got back to any of you, my college work has been hectic!
I appreciate all you explained to me though!
So thanks again
Xeomus
