Results 1 to 10 of 10
Thread: Program for PC
    Flashy's Avatar
    Flashy Guest
    Program for PC
    I'm loking for a simpel program where jou can get the same information like on a Pressure/temperature slide .
    Re: Program for PC
    Download CoolPack.
    sammycclass's Avatar
    sammycclass Guest
    Re: RD II shut down codes 77 71 61 please help
    [quote=sammycclass;205263]Hello
    I have Thermo King with a RD II shut down problem.
    Don’t know what to do any more I did check some wires look ok. Check oil and water ok
    Starts some times shuts down ride away and sometimes runs for a few minutes when I adjust the rpm screw to high rpm is ok so I get the fallowing codes 71 77 61 sometimes code 74 as well please help
    Thank you
    Oct 2003
    5,630
    Re: Program for PC
    Or Solkane from Solvay
    For Sammycslass, nobody will answer you post if you don't do the efforts to post it in the right section
    Sep 2006
    285
    code61 =low battery voltage try fitting a slave battery and run on test
    Flashy's Avatar
    Flashy Guest
    Re: Program for PC
    Download CoolPack.
    Thanks for the fast reply
    sammycclass Guest
    I did check all battery connection and power and ground all ok will start and turn off so I check contacts all ok check diesel in to fuel filter all ok check oil and water all ok removed circuit board cleaned all contacts with contact cleaner because I have seen some light mildew on the circuit board removed & reinstalled back now control panel in cab will not light up if I turn on black switch on position it will turn on and off buy itself so don’t know what to check any more please help.
    Thank you
    Apr 2009
    South Africa
    49
    108
    Re: Program for PC
    I have a pocket refrigeration calculator from DUPONT witch can do all T/P conversions in a split second for all common used gases. I got it from a local refrigeration spares company that cells DUPONT gases. So try your local gas supplier.Keep on Topic PLZ
    THE BEST WAY OF LEARNING IS TO DO IT YOURSELF!!!
    Jun 2006
    Arizona
    Re: Program for PC
    Quote Originally Posted by Flashy View Post
    www.exactchargehvac.com
    Click on ExactCharge Calculator on left hand side.
    Click on Conv key for SI Mode.
    Instructions are also available.
    Jun 2006
    Arizona
    Re: Program for PC
    Click on ExactCharge Calculator Icon on left hand side.
    Click on Conv key to convert to SI Mode.
    Free.
  1. Capillary Tube Program
    By Chef in forum Fundamentals
    Last Post: 14-02-2011, 08:21 AM
  2. Calculates heating & cooling loads program
    By athanatos13 in forum Tools and Calculators
    Last Post: 20-07-2009, 11:35 AM
  3. Replies: 40
    Last Post: 29-08-2008, 12:17 PM
  4. Danfoss program DIRCALC
    By smpsmp45 in forum NH3
    Last Post: 13-05-2008, 11:19 AM
