    johnrmckenzie's Avatar
    johnrmckenzie Guest
    Environmental Chamber Design
    I need some help specifying a refrigeration system for an environmental test chamber. The test chamber will be based on a 2 person glove box, and allow testing of a medical device inside the box under various extreme environmental conditions. The glove box, made from acrylic sheet, will be supplied with a means to heat it and control humidity, but no means for cooling. The target temperature is 5C, with the ability to hold that temp for up to a week. The box will have 4 glove portals, mostly sealed, and a large viewing window, but otherwise can be insulated. It will generally stay closed and will have an isolating passthru to avoid too much ambient exposure.
    A portable AC unit won't get it cold enough, so I have looked at refigeration units for walk in frig/freezers, but those seem overkill. Isn't there and 'off the shelf' solution for something like this?
    Thanks,
    John
    Re: Environmental Chamber Design
    Try medical equipment suppliers as they can cater for all and weird type equipment applications. Hugely expensive though, generally.
    Mar 2009
    U.S.A.
    320
    This thing need to last a long time or is this a 1-month duration type of experiment?
    Short of finding a used lab cooler or even a data center refrig unit: I would rig it up based on ice. Lots of used ice makers out there and in a pinch, a few dinero to the corner convenience store will refill or supplement the "bank". And its all flexible enough to support your next set-up....
  1. Design Help / Where to start?
    By Electric Rain in forum Fundamentals
    Last Post: 03-10-2010, 10:41 AM
  2. Saving energy in the design of low-temperature chamber
    By andrew1977 in forum Tools and Calculators
    Last Post: 19-04-2010, 12:40 PM
  3. environmental chamber
    By dumbmechanic in forum Technical Discussions
    Last Post: 24-11-2009, 05:25 AM
  4. Replies: 31
    Last Post: 28-11-2006, 10:32 PM
