Results 1 to 13 of 13
    Ludasmith's Avatar
    Ludasmith Guest
    Frequently used abbreviations and shorthand guide
    Hi Everyone, I am getting into refrigeration in case I decide to change my carrear direction.
    Reading through hese forums seems a mine of usefull information but reading some of the threads it seems that there are a lot of abbreviations used in the field.
    Im all for shortening things down, particularly for forums such as this but could we start putting a list together of abbreviations and their meanings? It would make the forum an easier place for newcomers like myself.
    Thanks, Luke
    Dec 2009
    Spain
    45
    229
    15
    Re: Frequently used abbreviations and shorthand guide
    Great idea!
    Jun 2009
    North East England
    41
    712
    Lets make a start then
    EXV- electronic expansion valve
    TEV-thermostatic/thermal expansion valve
    L/P-suction pressure/low pressure (sometimes called back pressure)
    H/P-discharge pressure/high pressure (sometimes called delivery pressure)
    O/P-oil pressure
    Delta T- temperature difference
    Delta P-pressure difference (delta represented by a triangle symbol)
    S/H- superheat
    S/C-subcooling
    EPR-evaporator pressure regulator
    SST-saturated suction temperature
    SCT-saturated condensing temperature
    SLT-suction line temperature
    LLT-liquid line temperature
    VRV-variable refrigerant volume (Daikin only)
    VRF-variable refrigerant flow
    *****-refrigerant
    HFC-hydroflourocarbon
    HCFC-hydrocloroflourocarbon
    CFC-cloroflourocarbon
    CARE REFRIGERANTS-hydrocarbons(flamable)
    COP-coefficient of performance
    GWP-global warming potential
    ODP-ozone depleting potential
    C&G 2079-the current qualification required in the uk to work on refrigeration and air conditioning equipment containing green house gases
    KYOTO PROTOCOL-climate change police
    HVAC-heating,ventilation and air conditioning
    ACRIB-air conditioning/refrigeration industry board
    IOR-institute of refrigeration
    And probably a lot more all i can think of off the top of my head.
    Sep 2010
    33
    PHE - Plate Heat Exchanger
    Just learned that one. Heh.
    Jun 2009
    North East England
    41
    712
    Office worker-Person/persons in office who call you out to a fault and spend the entire time telling you how to do your job insisting the unit is out of gas Grrrrrrrr
    Jun 2010
    saudi arab
    41
    82
    14
    hi dear
    comp. compressor
    cond. condensor
    evap. evaporator
    chl. chiller
    3,856
    Bmt - bulk milk tank
    Ibc - Ice bank control
    Cch - Crank case heater
    Oct 2001
    Nottingham UK
    5,668
    OFN Oxygen Free Nitrogen
    CCH Crank Case Heater
    SOG Short of Gas
    NO Normally Open
    NC Normally Closed
    DOL Direct on Line
    DOA Dead on Arrival
    3,856
    Totnbt - Tits or tyres, nothing but trouble.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    FDC, Forced draft coil. LLSV, liquid line solenoid valve. CPR, Cardiopulmonary resusutation... no.. Crankcase Pressure Regulator. RTFM (courtesy Chemi)..Read the #!$*&@ manual
    Apr 2008
    Southampton, England
    49
    1,023
    36
    Word Up Luke,
    Here are some Danfoss abbreviations worked out from one of their diagrams:
    KVR - Condenser Pressure Regulator
    KP15 - Combined HP/LP Switch
    NRV - Non Return Valve
    NRD - Differential Pressure Regulator
    KVP - Evaporator Pressure Regulator
    EVR - Solenoid Valve
    TE - Expansion Valve
    BM - Sut Off Valve
    KVL - Crankcase Pressure Regulator
    KP61 - Thermostat
    MP - Oil Pressure Differential Switch
    DX - Drier
    SGI - Sight Glass
    AKV - Electronic Expansion Valve
    Cheers,
    Andy.
    Jun 2009
    North East England
    41
    712
    HGD-Hot gas defrost
    DEF-Defrost
    CHW-chilled water
    Apr 2006
    stafford
    42
    974
    A heat transfer surface area, sq ft
    C air flow, cfm
    Cc coil air flow rate, cfm
    CLF Cooling load factor
    CLTD cooling load temperature difference, F
    Coa ventilation (outdoor air) air flow rate, cfm
    Cr return air flow rate, cfm
    Ed diffuse solar radiation on a surface
    ED direct solar radiation on a surface
    eh coil entering enthalpy, btu/lb dry air
    Er reflected solar radiation on a surface
    h enthalpy, btu/lb dry air
    hent coil entering air enthalpy, btu/lb dry air
    hlv coil leaving enthalpy, btu/lb dry air
    hr room air enthalpy, btu/lb dry air
    hrrs room required supply air enthalpy, btu/lb dry air
    K factor to correct CLTD for color
    LM correction to CLTD for month and latitude, F
    odb outdoor dry bulb temperature, F
    owb outdoor wet bulb temperature, F
    q local instantaneous heat gain or loss, Btu per hour
    Q space cooling load, Btu per hour
    Qrs room sensible cooling load
    Qrt room total cooling load
    Qscc Sensible Cooling Capacity of an air conditioning System
    Qtcc Total Cooling Capacity of an air conditioning System
    rdb room dry bulb temperature, F
    renth room enthalpy, Btu per pound of dry air
    rrsh room required supply enthalpy
    RSCL room sensible cooling load
    RTCL room total cooling load
    rwb room wet bulb temperature, F
    SC shading coefficient, modifies solar heat gain factor
    SCC Sensible Cooling Capacity of an air conditioning System
    SCL Sensible Cooling Load
    SHGC solar heat gain coefficient
    SHGF solar heat gain factor, function of latitude, month, orientation
    TCC total cooling capacity of an air conditioning system
    TCL total cooling load
    TD temperature difference between rooms or spaces.
    tdp dew point temperature, F
    tedb, edb coil entering dry bulb temperature, F
    tewb, ewb coil entering wet bulb temperature, F
    tldb, ldb coil leaving dry bulb temperature, F
    tlwb, lwb coil leaving wet bulb temperature, F
    to average outdoor ambient temperature, F
    tr, trdb return air dry bulb temperature, F (usually = trm)
    trm room dry bulb temperature, F
    trsdb room required supply dry bulb
    trswb room required supply wet bulb
    trwb return air wet bulb temperature, F (also room wet bulb)
    ts sol-air temperature, F
    U overall coefficient of heat transfer, Btu/(hr*ft2 *F)
    didnt come out very well when copy and pasted from word doc sorry
    Paul
    "KEEP IT COOL"
