Thread: superheat
30-09-2010, 03:32 PM #1
superheat
Can you tell me,how to meassure the superheat?i need the theorotical details...pls help me
30-09-2010, 03:34 PM #2
Re: superheat
How does the TX valve works?tell me the theory...
30-09-2010, 06:27 PM #3
Re: superheat
Search Google and this forum here is a start
http://www.refrigeration-engineer.co...ead.php?t=5135
30-09-2010, 08:24 PM #4
Re: superheat
My wife used to say you never listen to a word I say at least I think that what she said
01-10-2010, 12:19 AM #5
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,175
- Blog Entries
- 6
- Rep Power
- 36
Re: superheat
Did you tried this little search engine?
01-10-2010, 09:59 AM #6
Re: superheat
The expansion valve is a temperature initiated pressure operated device to regulate the flow of refrigerant through a coil. A phial sometimes called a bulb is mechanically attached to the suction outlet pipe and is both charged with the same refrigerant for which the system is being used and connected to a set of bellows [at the top of the valve] which in turn act upon the orifice [metering point].
If the temperature sensed by the phial is too cold or equally not cold enough the pressure within the loop from phial to bellows changes which in turn acts upon the orifice and thereby decreases or increases the volume of refrigerant flowing through the coil.
Superheat is simply the difference between the temperature of the refrigerant entering the coil and that leaving at the coil outlet. The reason for the differential being the heat picked up from the load during its passage across the coil face.
This is typically measured using a hand held thermometer.
Hope this helps.
9 superheat & subcooling scenarios
By nike123 in forum FundamentalsReplies: 39Last Post: 19-07-2011, 03:16 AM -
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 02:24 AM -
Carrier 23xl chiller-Low discharge superheat alarms
By Bradysmill in forum Trouble ShootingReplies: 7Last Post: 25-04-2010, 07:43 PM -
Subcooling at TEV vs Superheat at Compressor relation in Steady State
By GXMPLX in forum FundamentalsReplies: 12Last Post: 14-07-2008, 03:00 PM -
Superheat
By shogun7 in forum FundamentalsReplies: 24Last Post: 23-08-2004, 05:54 PM
