Thread: Electrolux Service Manual?
30-09-2010, 03:06 PM #1
Where can I purchase an Electrolux service manual for a model#EW23BC71IS refrigerator?
Nickyd
30-09-2010, 07:54 PM #2
Re: Electrolux Service Manual?
hi you could posibly get a manual from your electrolux shop,
did you get your manual nickyd?
01-10-2010, 05:30 PM #3
No. I don't know where to get it.
01-10-2010, 09:03 PM #4
Electrolux manuals are only available to service agents.If you have a problem put it on here we can usually help.
06-10-2010, 08:06 PM #5
I have a Electrolux French door refrigerator that has excessive condensation between the two top doors. Is there a mullion heater for this area?
Nickyd
07-10-2010, 08:29 PM #6
Sorry didn't notice you are in the US.
Used to work for Electrolux in the UK but the two companies had a parting of the ways so don't know your machine.
Condensation fault could be due to a door seal having a small gap,tear a thin strip of paper,open door and close on the paper,try to pull paper out,if there is resistance door seal is OK in that spot but you need to check the area nearest the condensation.
BG
08-10-2010, 06:27 PM #7
What about a mullion heater for the door to prevent condensation?
Carrier 30GX Service Manual Required
By Hatchy in forum Refrigeration BooksReplies: 25Last Post: 05-11-2010, 07:58 PM -
Need help for buus ice flake service manual
By tolome in forum Refrigeration BooksReplies: 2Last Post: 30-06-2010, 10:18 AM -
Service manual for Samsung AQV24FAN
By RegeX in forum Air ConditioningReplies: 6Last Post: 11-12-2009, 09:54 PM -
daikin service manual help
By omurcelik in forum Air ConditioningReplies: 2Last Post: 28-05-2008, 01:42 PM -
SL/SB-400 Pump Down Procedures
By absolute-zero in forum TransportReplies: 1Last Post: 29-01-2008, 09:27 PM
