Thread: Daikin Code 50 & 60
29-09-2010, 09:42 PM #1
Daikin Code 50 & 60
Hi guys, we need help on accessing Daikin code 50 & 60 menus can any one help pls?
29-09-2010, 11:18 PM #2
Re: Daikin Code 50 & 60
Remind me please, what are 50/60 codes for?
30-09-2010, 03:12 PM #3
sure i can help u,tell me your actual problem....
30-09-2010, 03:50 PM #4
Thought that some of these codes are for factory re-programming of the application spec etc. Not all of them are applicable to all units.
Some can be used to alter the capacity limit of the VRV and some can be used to blank out the remote controller.
Be very careful how you use these codes as some are claimed to be non-reversible.Mobile A/C at its best, see avatar.
30-09-2010, 06:00 PM #5
Daikin do NOT release these codes even some of the daikin guys do not have them if your problem is this high up in the code ranking then i think it would be sensible to call daikin out, after all the cost of kit these days isn't cheap and from what i was unofficially told by a chap from a major manufacturer these codes can cause serious damage to equipment
30-09-2010, 07:35 PM #6
Hi, we are building a test rig and we have been advised that one of the code 60 if set will set the indoor unit so it does not look for an outdoor unit?
30-09-2010, 07:39 PM #7
01-10-2010, 08:59 AM #8
Hi James10, thks for the input, we have tried this however on VRV indoor boards they will still display certain fault codes even when set to fan only.
03-10-2010, 01:00 PM #9
what fault codes are you getting and then we can see what measures can be taken to get rid of them.
03-10-2010, 06:50 PM #10
ahh the 50s and 60s
in general they are pretty useless and are fan coil specific. one of them 60-7-02 turns off all fault codes, its used for building simulation rigs.
some of the others in the 50s are good, they can fully close exp valves in the fan coils in heating mode. One of them changes superheat when using r22 fan coils on r407c etc. In brief they are of no use in the real world so dont play.
Daikin wont release them, they are not allowed to, changing these can effect the unit hugely voiding warranty.
if you wanna play good luck but they are impossible to reset so have a supply of new pcbs at hand if you want to change them.
there is a powerpoint presentation around with all the 50s and 60s on it and how to set em, ask the old boys at daikin for a copy if they like you they will do you proud.
good luck
Graham
11-10-2010, 10:38 PM #11
Only some of these codes are usefull, they are mainly for programming refrigerant clasiffication, expansion valve control, capacity setting, reading outdoor unit data via the remote, addressing with no centralised connected etc, they can be reset if you play around with them, but you need to know what you want to do before you play. The codes cannot be released. There are many more things you can program by service codes in the indoor units and outdoor PCB's by using the setting modes, but these are not released for a reason, stick with whats available, it should be all you need
HELP with Daikin split system "P2" error code
By HVACNYC718 in forum Trouble ShootingReplies: 8Last Post: 05-06-2011, 01:48 PM -
Daikin UF fault code
By deyna in forum Trouble ShootingReplies: 7Last Post: 06-08-2010, 12:47 PM -
Daikin E5 code
By The captain in forum Air ConditioningReplies: 5Last Post: 09-04-2010, 01:14 PM -
Daikin r407c 2 pipe vrv ja fault code any offers?
By Contactor in forum Air ConditioningReplies: 11Last Post: 28-07-2009, 01:26 AM -
Daikin secret's code, is it true? How?
By cool#9 in forum Air ConditioningReplies: 24Last Post: 20-12-2007, 01:11 PM
