28-09-2010, 05:09 PM #1
Daewoo erf 336 Fridge not cooling Freezer OK
I have had above problem for about a week now. No cool air coming into Fridge compartment . Checked fan is working (or is turning ) Checked airway from freezer to fridge is clear , but still no cooling. Any help appreciated
25-10-2010, 09:59 PM #2
Re: Daewoo erf 336 Fridge not cooling Freezer OK
try turning it off for 24 hrs leave the doors open,sometimes ice builds up on the evaporater ,the cold air for the fridge comes from the freezer up a chute which sometimes gets a bit iced up and stops the cold airflow,make sure you empty the drip tray at the back,and put dowm a towel just in case
25-10-2010, 10:55 PM #3
if fridge ducted air is controlled by baffle,
motor could be faulty, or control faulty, ie sensor or stat fault
26-10-2010, 12:13 AM #4
On that model if there is a build up of ice inside the freezer it's usually the defrost timer. It's located on the right hand side of the centre panel inside the fridge. Three screws holding the panel on, one behind the light cover
daewoo fridge freezer
By dave grant in forum DomesticReplies: 1Last Post: 20-07-2010, 07:58 PM -
LG Side by Side Fridge Freezer not cooling or freezing
By nickphill in forum DomesticReplies: 6Last Post: 01-04-2010, 11:29 AM -
indesit ba13s fridge is not working right and freezer slighly frosting up
By no_mercy in forum RefrigerantsReplies: 0Last Post: 11-10-2009, 02:38 PM -
Hotpoint Mistral Fridge Freezer Plus. Fridge won't cool
By Redmeister in forum Trouble ShootingReplies: 2Last Post: 09-07-2009, 06:25 PM -
Liebherr Fridge freezer 13 and -18 degrees
By jensenengland in forum Trouble ShootingReplies: 3Last Post: 05-07-2009, 07:48 PM
