Results 1 to 12 of 12
Thread: How do you remove ice from coil?
28-09-2010, 04:49 PM #1
Whats the best way to remove ice from evaporator coil?
Coil is in walk-in freezer at 10 F. Trying to remove ice without raising ambient temp too much.
28-09-2010, 05:17 PM #2
Re: How do you remove ice from coil?
Melt it.
Water, Big hair drier, compressed air, .....
28-09-2010, 05:27 PM #3
de-icer works a treat if working conditions allow
28-09-2010, 07:21 PM #4
defrosting
28-09-2010, 07:22 PM #5
28-09-2010, 09:26 PM #6
THE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
29-09-2010, 03:56 AM #7
I came across some infrared clamp-on heat lamps that I use after pulling fan blade and motor assm. The clamp holds on to the coil opening and being infrared heats only surface and not air. They cut thaw time more than 50% but I only use them with thick ice. Just be safe and make sure they don't allow water to drip on them.
Don't leave it like you found it.....Leave it like it should be !!!
29-09-2010, 10:58 AM #8
its funny but our target is to make ice and freeze things and at the same time...ice is our worst enemy! i agree with goshen,hot wateris another solution
30-09-2010, 12:27 PM #9
what i do is pump down the sytem, wire in the defrost contactor with the fans of, go for a few cups of tea, come back and pull the ice of the front and back of the coil, then investagate as to why its icing up, all of this depends if its electric defrosts!!
30-09-2010, 12:31 PM #10
Try using reverse cycle, however program the evaporator fan to be switched off during the cycle.
30-09-2010, 07:26 PM #11
If i'm in no rush, hold the unit on defrost till ice clears. Fastest way is hose pipes and hot water but not always possible if shop is open. For small units I carry a Large flower pump sprayer that I fill with hot water. Obviously you have to see why its iced up in the first place.
01-10-2010, 02:52 PM #12
coil sizing - custom project..
By cadillackid in forum Heat PumpsReplies: 0Last Post: 24-04-2010, 07:57 PM -
Temperature problem with liquid NH3
By energeia in forum NH3Replies: 34Last Post: 05-08-2009, 08:16 AM -
About 2 stage coil
By cstyx in forum Technical DiscussionsReplies: 3Last Post: 09-04-2009, 08:26 PM -
Dont be shy, advice needed.
By Sledge in forum Air ConditioningReplies: 9Last Post: 27-06-2007, 03:09 PM -
Article in ACH&R News
By Gary in forum FundamentalsReplies: 8Last Post: 20-05-2003, 12:27 AM
