28-09-2010, 01:13 PM #1
Re: rack-mounted cooler system for computers
Yeah, that's a commonly installed system. Please contact Aquacooling http://www.aquacooling.co.uk/ . They will also supply a system for leak prevention under negative pressure.
Don't forget that a leak in the door coil would spray the computers.That's where a negative pressure system comes handy.
28-09-2010, 02:38 PM #2
Rittal do both versions. a DX door or roof mounted cabinet cooler or a water cooler version
http://www.rittal.co.uk/products/sys...rol/index.html
They also do a very high spec server room cooler but that will be well outside your budget
How to change (retrofit) a quite a meat cooler with R12 to r134a system.
By Ray Vella in forum FundamentalsReplies: 15Last Post: 26-08-2010, 01:47 PM -
Solenoid Valves in Parallel Compressors Rack System
By georgedvf in forum Technical SpeculationsReplies: 40Last Post: 18-08-2010, 12:59 PM -
Daikin UF fault code
By deyna in forum Trouble ShootingReplies: 7Last Post: 06-08-2010, 12:47 PM -
What is System balance?
By shogun7 in forum Technical SpeculationsReplies: 56Last Post: 19-01-2006, 09:47 AM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM
