    yoursvaithi's Avatar
    yoursvaithi Guest
    Question Small chest freezer-Heat load
    fficeffice" />>>
    How to calculate the heat load of small ice cream chest freezer....>>
    Dimensions 1600(L)x600Hx500W and the PUF wil be 50mm pls clarify the both if its having Glass door and 50 mm solid door??????? and also how to select the complete components like compressore,Evep,Condenser...pls help>>
    Aug 2009
    New Zealand
    2,554
    Re: Small chest freezer-Heat load
    Go to school and learn refrigeration
  1. Calculating heat load
    By Abe in forum Technical Discussions
    Last Post: 13-08-2010, 05:40 PM
  2. Basics or is it?
    By Fett in forum Fundamentals
    Last Post: 10-09-2009, 01:45 AM
  3. Calculating heat load from return air ?
    By ssnrcs in forum Tools and Calculators
    Last Post: 30-08-2009, 06:38 PM
  4. Cooler with additional heat load.
    By pedersrg in forum Fundamentals
    Last Post: 23-06-2009, 10:44 PM
  5. Supermarket heat load calculation
    By nike123 in forum Air Conditioning
    Last Post: 23-04-2009, 09:34 AM
