Thread: Peltier Coolers
27-09-2010, 08:44 PM #1
Peltier Coolers
Has anyone ever had much dealings with TECīs (peltiers)?
I need a small amount of cooling so they seem the obvious choice, but Iīm getting conflicting views on controlling them. From what Iīve seen thermostat control is bad for them, PWM is bad for them. So what are you supposed to do?
I have looked at a wine chiller and that I think uses PWM and computer overclockers I assume just use on/off controls.
I donīt want to spend a lot on controller, Iīd just make something to incorporate into my project. Any help would be greatly appreciated.
27-09-2010, 08:52 PM #2
Re: Peltier Coolers
Ask the manufacturers, try gooooooooooooooogle
27-09-2010, 11:06 PM #3
Re: Peltier Coolers
I was going to direct you to a previous thread which discussed some of these problems.
Changed my mind when I realised that you were one of the major contributors. DOH!
Remember the lady with the vivarium?Brian - Newton Abbot, Devon, UK
27-09-2010, 11:31 PM #4
Re: Peltier Coolers
It comes down to what level of temperature control you require.
remember that these are DC, so changing the voltage input changes the refrigeration effect. TEC are good thermal conductors when they are off, so it is better to leave a trickle charge going through.
28-09-2010, 08:41 AM #5
Re: Peltier Coolers
Yeah, I remember. In fact I am doing almost exactly the same thing as what is in that thread.
The modules themselves, I have no problem with, I understand the heat sinks and all that. Itīs just the controls and power supplies. Temperature wise itīs not going to be cold at all really, I only need a temperature 27šC and it doesnīt need to be that accurate, within a degree of that will suffice.
If for example, I had 2 supplies (say, 12v and 1,5v) and supplied the TEC with 12v when thermostat on and 1,5v when thermostat off, would that be sufficient to maintain a steady-ish temperature while not damaging the TEC or does the transition need to be smooth?
28-09-2010, 09:27 AM #6
Re: Peltier Coolers
http://www.seattlerobotics.org/encod.../variable.html
Would this kind of variable voltage power supply be useful?Engineering Specialist - Cuprobraze, Nocolok, CD Technology
28-09-2010, 11:39 AM #7
Re: Peltier Coolers
Possibly if it was made a bit more powerful and robust. Iīve not done the sums yet, but I think that I am going to need about 50watts of cooling, plus fans, etc so I would need a power supply capable something higher than that. Probably 100w power supply would be sufficient. Itīs more the method of how to feed the TEC really.
28-09-2010, 07:48 PM #8
Re: Peltier Coolers
Whichever is used the fans can be fed from a "simple" power supply, maybe cheaper????
08-10-2010, 05:45 AM #9
Re: Peltier Coolers
yes you can search the answer for your problem at different search engine.
Walk in cooler & walk in coolers
By henrymark in forum CommercialReplies: 3Last Post: 18-08-2010, 02:43 AM -
Husky bottle coolers
By dunny123 in forum CommercialReplies: 11Last Post: 24-08-2009, 11:10 PM -
Peltier wine cooler
By shanes696 in forum New TechnologiesReplies: 5Last Post: 14-12-2005, 10:40 PM -
thermoelectric air coolers?? Is it suitable??
By johnnysoprano in forum FundamentalsReplies: 3Last Post: 06-08-2005, 10:48 PM -
(Remote) Back bar coolers
By Chris2005 in forum CommercialReplies: 3Last Post: 20-03-2005, 09:31 AM
