27-09-2010, 01:28 PM #1
shell and tube heat exchanger design
Is there a rule of thumb in designing a shell and tube condenser? if non how do you have any links to provide so i can study the design. Because my boss only taught me his rule of thumb with really explaining how he do it. And when i select the design i just based it on the manufacturer catalog.
thank you
lynark
27-09-2010, 03:28 PM #2
Re: shell and tube heat exchanger design
Well, you need to know surface, LDTM, specific heats of fluids, bla bla bla... are you a manufacturer of s&t condensers?
28-09-2010, 12:00 AM #3
Hi NNN,
More of a local fabricator. We fabricate our own shell and tube condenser for the refrigeration system. So I want to know how they compute it, because right they are using a standard selection. I mean for example 89TR capacity, they will use 6 pass of 26" x 18' because of the sqft surface area. I don't know if its correct or what are the computation behind it.
28-09-2010, 07:38 AM #4
One hell of a condenser!
You could use coolpack and calculate the heat transfer of each pipe individually.
28-09-2010, 08:15 AM #5
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
This is cheap software:
http://www.freedownloadscenter.com/B...er_Design.html
This one is expensive:
http://www.lv-soft.com/software/fach...ngers.wts..htm
29-09-2010, 11:52 PM #6
29-09-2010, 11:53 PM #7
Shell and tube Heat exchanger Design
By sanjay261289 in forum FundamentalsReplies: 2Last Post: 25-06-2010, 12:02 PM -
Fabrication of Cooler Tube & Shell Cooler
By rickyccong in forum Technical DiscussionsReplies: 1Last Post: 27-07-2009, 02:25 PM -
ERBAY shell and tube heat exchanger
By chemi-cool in forum Air ConditioningReplies: 3Last Post: 04-06-2008, 05:15 AM -
Vahterus Heat Exchanger
By samiam in forum New TechnologiesReplies: 4Last Post: 19-04-2008, 10:33 AM -
R134a / Water Heat Exchanger Sizing
By ACEprod in forum CPU OverclockersReplies: 0Last Post: 31-03-2008, 07:34 AM
