Results 1 to 9 of 9
Thread: measure sub-cooling
24-09-2010, 06:34 PM #1
measure sub-cooling
Can anybody tell me,which is the correct point to take high pressure to measure sub-cooling.At compressor discharge valve or at liquid line before the expansion valve???
24-09-2010, 06:59 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: measure sub-cooling
For checking that you have enogh subcooling to prevent flash gas before TXV, at liquid line before expansion valve.
For checking refrigerant charge, at condenser outlet.
Pressure should be measured where temperature is measured. If not possible, than you need to take in consideration pressure drop from measuring point of pressure to measuring point of temperature.Last edited by nike123; 24-09-2010 at 07:03 PM.
24-09-2010, 07:34 PM #3
How can you calculate pressure drop nike??
24-09-2010, 08:45 PM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
You could use Cool-pack.
But, if length of pipes and number of fittings are small you could round that pressure loss or ignore it, if you could picture in your head how much approximately that would be.
Try with excersizeing on real examples from your work by noting pipe diameters, pressures and temperatures, power of system and then calculate in Cool-pack. That will give you feeling.
25-09-2010, 07:34 AM #5
What is coolpack?
25-09-2010, 07:50 AM #6
Nike,
You're very patient
25-09-2010, 08:11 AM #7
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
25-09-2010, 08:12 AM #8
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
25-09-2010, 08:21 AM #9
Thanks for the information nike
Cooling problem with VRV REYQ24M7.
By cool#9 in forum Air ConditioningReplies: 3Last Post: 07-02-2010, 12:20 PM -
measure sub cooling properly
By johnny cool in forum FundamentalsReplies: 7Last Post: 24-03-2009, 05:43 PM -
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM
