    Chiller biginer's Avatar
    Chiller biginer Guest
    york chiller Solid state starter starting current
    Hi all. I 'm new at this site. I need your helps.
    I want to know
    How much current is occur when I start York 400t chiller with solid state starter.
    chiller spec says that the rated amps is around 300A, but when I start it, it looks like use much more than 300A.
    Anybody know about starting current, please help me
    Aug 2008
    UAE
    5
    Re: york chiller Solid state starter starting current
    You need to check the motor datasheet and look for the Locked Rotor amps value (LRA). A typical solid state starter inrush will in the 45 to 50% of the LRA value
    Auckland
    74
    3,357
    38
    most soft starters have adjustable ramp up times. DOL starting is something like 10 times the LRA.
  1. Maximum Starting Current
    By weeliang82 in forum Air Conditioning
    Last Post: 29-04-2010, 04:15 AM
  2. York Reciprocating Chiller - %Motor Current
    By subdude in forum Trouble Shooting
    Last Post: 28-07-2009, 05:49 PM
  3. Solid State Starter
    By pinto joseph in forum Technical Discussions
    Last Post: 04-02-2009, 05:32 PM
  4. York Solid State Starter Fault
    By Bill at 101 in forum Trouble Shooting
    Last Post: 04-12-2008, 06:01 AM
  5. York Water cooled solid state starter?
    By Dave the Fridge in forum Trouble Shooting
    Last Post: 27-03-2007, 05:03 PM
