Thread: Altherma Error Code A6
24-09-2010, 08:30 AM #1
I have a Daikin Altherma HT (ERSQ011AAY1/EKHBRD011AY1) 11kW heat pump.
I get an Error Code A6 on the display panel and the red LED light on the panel starts blinking. This error already happened twice this week. When it happend, the Central Heating hot water production stops although the Domestic Hot Water production still works.
I checked the manual and it says M1P pump failure.
Any ideas if this require professional assistance or if I can fix it?
24-09-2010, 11:16 PM #2
Re: Altherma Error Code A6
Can you access the pump?
Is it air locked, is it free to rotate ?Brian - Newton Abbot, Devon, UK
25-09-2010, 08:58 AM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,175
- Blog Entries
- 6
- Rep Power
- 36
It look like diverting valve is having problem or central heating system water filter (if it is separate one) is dirty.
Every year before start of heating season your system should be examined and started by professional. Pump (and other moving parts on water side) could block after staying still for prolonged period of time (non-heating season) and need to be manualy started (by screwdriver) before start up of system if unit doesnt have prevention of pump blockage.Last edited by nike123; 25-09-2010 at 09:03 AM.
07-12-2010, 12:36 AM #4
yes i would say a dirty filter..
07-12-2010, 08:52 AM #5
Filter is not to tricky to get to on these units its on the water return towards the bottom left of the unit worth cleaning fairly regular any way. Roger
Altherma frequent compressor cycling
By afternine in forum Heat PumpsReplies: 80Last Post: 29-10-2010, 11:03 AM -
Altherma Cooling Performance?
By pmwillia in forum Heat PumpsReplies: 0Last Post: 20-08-2010, 03:07 AM -
Altherma v Inverter Splits/Mini VRF
By Makeit go Right in forum Air ConditioningReplies: 0Last Post: 18-07-2010, 05:33 PM -
How are the Daikin Altherma units?
By LucMan in forum Air ConditioningReplies: 11Last Post: 15-07-2010, 11:08 PM -
Callling everyone with Altherma experience
By Contactor in forum Heat PumpsReplies: 2Last Post: 15-07-2010, 10:38 PM
