Results 1 to 13 of 13
    Sep 2009
    india
    38
    Dear friends,
    pl help me to find out the problem
    we have installed 20tr glycol chiller with ammonia systems for chilling 10,000ltr/hr milk by alfa laval PHE.
    we designed for chilling milk from 8 degree to 6 degree celcious(i.e 6degree drop)
    but practically we give input milk is 6degree only
    but we getting output milk temp is 3.5degr to 4 degree only(i.e is 2.5 degree drop only)
    we gave the coolant side glycol temp is -5.5 degree to -6 degree
    but we didn't get at least 5 degree drop
    the milk chiller heat transfer area is 3.84m^2
    pl anybody help me
    whether the designed system is correct or not?
    u can send ur idea to my mail box
    munakp@gmail.com
    im very much thankful to you,
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Milk chiller problem, pl help me
    And the leaving glycol temperature is?
    Sep 2009
    india
    38
    Quote Originally Posted by NoNickName View Post
    it is -2*c only
    Sep 2009
    india
    38
    Quote Originally Posted by muna View Post
    it is -2*c only
    we designed for chilling milk from 8 degree to 2 (not 6 degree as i mentioned) i.e 6degree drop
    Mar 2006
    Merate (LC) - Italy
    2,549
    Milk is approximately heavy as water (1.032 for raw milk).
    On the warm side:
    20TR = 70kW
    70kW with a volume flow of 10000ltr/h gives a dt = 6°C therefore the leaving milk temperature is 2°C, but the wall temperature is -0.91 for a leaving glycol temperature of -1°C, very close to freezing temperature of milk (-0.55).
    In my opinion, the heat exchange in your case is limited by formation of frosted milk on the plates.
    Aug 2009
    New Zealand
    2,554
    26
    On the warm side:
    20TR = 70kW
    great minds think alike
    Sep 2009
    india
    38
    yes , u are absolutly correct dear, one time we did CIP cleanning with dismandling plates, we seems that there were some milk freezed pieces,
    so we put a automatic temp control actuator valve, it never allowed to freeze the milk, if once touching 2*C it ll stop the glycol flow,
    so tel me what is the input parameter must to cool the 10000ltr/hr milk @6*c input(i need glycol in temp and suface area of pHE)
    Sep 2009
    india
    38
    Quote Originally Posted by mad fridgie View Post
    thank you so much mad Fridge for your valuable words & advice , pl give me the comple design,
    Thnx in advence
    Mar 2006
    Merate (LC) - Italy
    2,549
    I think you should not cool the milk at a temperature below 4°C.
    Sep 2009
    india
    38
    hmm, now im getting outlet milk @ 2*C for 6000ltr/hr, but i need same temp for 10,000ltr/hr
    Mar 2006
    Merate (LC) - Italy
    2,549
    Increase the surface of exchange
    3,856
    Which fluid are you measuring to get 2C ?
    If its the milk that might be you problem as the outlet temp won't tell you if there is ice on the plates, (ice will act as an insulator so the milk will be touching ice at 0C and not a stainless steel plate at -6C)
    The only glycol chiller system i have seen ran at around -3C and controlled the flow of glycol into the plate cooler based on the temperature of the glycol coming out, the colder the outlet temp the less glycol flow.
    I have installed some ice builder systems that have supplied chilled water at 0C to a two stage plate heatexchanger with mains water to the first stage and our milk outlet temperature was around 2.5C, this was direct from the milking parlour so the milk was at cow body temp, so i'm not sure you necessarily need such a low starting glycol temp.
    The other thing i would ask is are all the plates in the correct way in the plate heat exchanger?
    Sep 2003
    ISRAEL
    72
    4,248
    The two Glycol system I maintain from time to time have milk feeding pumps with speed controlled by the milk outlet temp.
    The Glycol feeding temp is -0.5°C to -2.5°C.
    Thats the right thing to do.
  1. problem with multistack chiller
    By bright in forum Refrigerants
    Last Post: 30-10-2010, 10:43 PM
  2. Carrier chiller basic board problem
    By noushad123 in forum Trouble Shooting
    Last Post: 17-06-2010, 06:55 AM
  3. Problem with centrifugal chiller
    By engalmohannad in forum Commercial
    Last Post: 19-04-2009, 10:00 PM
  4. York YK Chiller Problem
    By icebox in forum Refrigeration Books
    Last Post: 01-07-2008, 06:05 PM
  5. Chiller tripping Problem
    By bhasadu in forum Trouble Shooting
    Last Post: 21-06-2008, 09:12 AM
