Thread: Pressure monitors
22-09-2010, 10:44 AM #1
Pressure monitors
My query is regarding the location of the pressure monitoring sensors to be installed in the Operation room of a Hospital. The initial design was to monitor the pressure between the OR and the Clean core area which are both at positive pressure and are clean areas. I would like to change the location of pressure
monitors to monitor the pressure between OR and the adjoining corridors or otherwise known as Dirty corridor. Is this permissible?
or am I missing something here?
22-09-2010, 04:10 PM #2
Re: Pressure monitors
You can fit equipment to monitor whatever pressures/rooms that you want to.
As long as you can prove that the pressure differential is correct across the various rooms/areas then all should be well.Brian - Newton Abbot, Devon, UK
02-10-2010, 08:09 PM #3
Thanks for the reply Brian..
Evaporating pressure valve
By civic9696 in forum Technical DiscussionsReplies: 0Last Post: 26-08-2010, 05:20 AM -
NVQ 3 online test
By Burrah Boy in forum TrainingReplies: 7Last Post: 28-10-2009, 08:35 PM -
Effect of inverter on Pressure Ratio
By GIB in forum Air ConditioningReplies: 6Last Post: 03-10-2009, 01:54 PM -
How can I reduce evaporator pressure?
By mansari in forum FundamentalsReplies: 29Last Post: 05-09-2009, 01:59 AM -
TEV capacity related to pressure drop
By DaBit in forum CPU OverclockersReplies: 8Last Post: 06-12-2002, 05:11 PM
