Threaded View
22-09-2010, 06:33 AM #1
using alkylbenzene 200 in HC system
I have a ice maker bank type chiller for industrial machine cooling (cools 100 gallon tank of water that circulates through machines and it was using 134 and POE oil, I have to replace the compressor that is filled with Alkylbenzene oil and I am converting to an HC blend. The system has several small 'holding' tanks and I was worried POE oil could be lurking there that might cause problems. There shouldn't be very much left but could the POE oil mix with the alkylbenzene oil okay?
I am replacing the sight glass and drier.
Thanks!
Daikin fault codes
Residential R-22 system. HO added 134a
By Magnapro in forum Technical DiscussionsReplies: 5Last Post: 26-05-2010, 09:12 PM -
Enthalpy Increasing Buffer System
By Reflexive in forum Technical SpeculationsReplies: 3Last Post: 23-12-2008, 03:18 PM -
Fan model for system optimization
By autt in forum System OptimizationReplies: 8Last Post: 31-03-2007, 05:34 AM -
Automotive A/C Vent Temp Range vs System
By Don Browney in forum Air ConditioningReplies: 1Last Post: 15-05-2002, 06:19 AM
