    Sep 2006
    Venezuela
    259
    Pump for Ammonia Transfer System
    Dear friends
    I am looking a ammonia pump for:
    3m3/h
    h= 2,5 bar
    NPSHD 0,45 m
    Which type of pump meets this conditions
    Please watch the NPSHD
    Gwapa
    Oct 2003
    5,630
    34
    Re: Pump for Ammonia Transfer System
    Sep 2006
    Venezuela
    259
    Thanks Peter 1
    I think that with a NPSHA of 0,45 m the pump should be a gear or vane pump. doesn't it?
    This gear or vane pump came in hermict type model?
    Thanks again Peter 1
    Mar 2009
    U.S.A.
    320
    Low NPSH avail will lead you to low speed gear pump (or potentially vane; only one I know of in refrigerant use is the Blackmer and generally they are much larger than this duty...and do not work so well slowed down).
    There are plenty of gear type, mag coupled pumps and some will work at low NPSH if you slow them down a level of motor speed. At 900 RPM/60 Hz liquiflow can provide an all-stainless pump with just about the right flow and head.
    With all gear pumps: They don't tolerate metal fines. With these pumps: You largely do not repair them they are a one-lifetime arrangement...So slower is better.
  1. Residential R-22 system. HO added 134a
    By Magnapro in forum Technical Discussions
    Last Post: 26-05-2010, 09:12 PM
  2. System Burn Out Troubleshooting
    By altaf22m in forum Technical Discussions
    Last Post: 07-05-2010, 09:24 AM
  3. Replies: 14
    Last Post: 27-08-2008, 08:57 PM
  4. Pump down or not - Dual compressor system
    By Electrocoolman in forum Commercial
    Last Post: 10-11-2006, 08:34 PM
  5. System Pump Down
    By Brian_UK in forum Technical Speculations
    Last Post: 25-10-2001, 10:39 PM
