Results 1 to 13 of 13
Thread: design
19-09-2010, 06:09 AM #1
design
Hi all; I made a design 4 cold store in a city where the temp. reach 46 C. I thought the basement could be used 2 make energy saving as there will be no direct solar radiation & the ceiling will be cold as it is the floor of refrigerated rooms also.
I couldn't know the temp of the basement before the design is implemented, as 2 calculate the RE load.
Please advice
Thanks in advance
Sonic
19-09-2010, 08:54 AM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: design
Most likely 12-14°C.
20-09-2010, 03:34 AM #3
Re: design
I would reckon the basement temps would be equivalent to average ground temps surrounding the basement.
magoo
23-09-2010, 08:20 PM #4
Re: design
Nike123;
Thank you, is it a ratio from the 46C or your expert estimates.
Magoo;
Thank you; but I cant get the surrounding ground temp. I only know the air temperature.
23-09-2010, 09:50 PM #5
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
23-09-2010, 11:20 PM #6
Re: design
Check the air temps in basement and compare to the wall temps, drill a hole in wall and check ground temps and the floor as well. If +46C outside I would figure ground temps in the 30's
24-09-2010, 07:24 PM #7
Re: design
Do u think the energy saving & hence the cost saving I aim 2 achieve deserve this basement building?
25-09-2010, 02:40 AM #8
Re: design
Hi Sonic.
anything thats saves power will be cost effective. Access to the basement area is another consideration.
26-09-2010, 03:11 PM #9
Re: design
Magoo & Nike123
Thank you 4 your help. I do appreciate this. now I'm going 2 complete my job.
09-10-2010, 12:10 PM #10
Re: design
Dear Nike123 & Magoo
I want to calculate the load for each of the rooms I've desiged & I want it to be as accurate as possible so I think I should use a software, do u know any load caculatig software has free trail versions or any simplified way. I'm time bounded.
09-10-2010, 04:29 PM #11
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
10-10-2010, 02:04 PM #12
Re: design
Many Thanks Nike123
10-10-2010, 02:12 PM #13
Re: design
I met a geological Dr in my city he told me that average temp 3 meters underground is 28 C, your estimate is amazing.
What design factors decides power comsumption
By kln in forum DomesticReplies: 3Last Post: 28-01-2008, 08:29 PM -
Efficient Water-Source Condenser Design?
By Enginerd in forum FundamentalsReplies: 4Last Post: 28-05-2007, 05:11 AM -
Replacement fo CO2 Bulk Tank refrigeration unit
By pabs_ref in forum CO2Replies: 31Last Post: 28-11-2006, 10:32 PM -
How to Design Refrigerated Cabinets
By Rayin in forum FundamentalsReplies: 5Last Post: 26-11-2006, 08:27 AM
