Thread: Flux ?
17-09-2010, 08:30 AM #1
Flux ?
Hi All, Flux how is it best used, dip the hot rod, make up a paste, dust the pipe with a brush before inserting, or use a rod with a higher silver content if so how much % wise what do you use/do
Devlin
17-09-2010, 08:45 AM #2
Re: Flux ?
The first and most important, clean the joints to be soldered till they shine, no oil residues.
I use on copper to copper 2% silifus rods and some times 5%.
If you use high silver content rods then you need flux.
Just heat the area to be soldered, add a small amount of flux and once its melted add the rod and with the flame cone, heat up the joint till it is full with the solder metal.
17-09-2010, 08:00 PM #3
Re: Flux ?
As Chemi says, you don't need flux on copper to copper joints (also copper plated driers and sight glasses, and danfoss tev's) with rods with between 2% and 15% silver.
You need flux with 38% or 40% silver rods which you'd use on copper to brass or steel.
I buy the flux coated rods, they are plastic coated so the flux stays on, or i use plain rods and dip them in dry powder, i don't like the idea of mixing flux with water in a refrigeration use.
Jon
20-09-2010, 07:52 AM #4
Re: Flux ?
pretty much as I do I had a discussion with someone who had some differing ideas and I wanted a concensuss
Dev
Brazing vs. soldering
By DaBit in forum FundamentalsReplies: 28Last Post: 19-03-2011, 11:50 AM -
Flux and no flux brazing
By SkyWalker in forum FundamentalsReplies: 7Last Post: 09-05-2010, 10:43 AM -
Star High Flux Chiller
By dallan in forum Trouble ShootingReplies: 3Last Post: 10-11-2007, 06:05 PM -
Brazing practice
By Larry2 in forum FundamentalsReplies: 13Last Post: 03-12-2006, 10:50 PM -
wall heat transfer coefficient measurement
By Lc_shi in forum FundamentalsReplies: 4Last Post: 30-10-2006, 01:15 AM
