    paulc81's Avatar
    paulc81 Guest
    bock f3 24 clutch
    hi all.
    I have installed a bock f3 compressor on a fishing boat engine with 24v clutch.(I have installed lots f2 compressors with same clutch all working correctly)after couple days the clutch burns out melting and destroying the hub to.the clutch is a 6in clutch.I think the clutch is not big enough to drive the compressor and is slipping and burning out,but the supplyer says its big enough.
    The system is running on r404a and is running at 1bar suction about 13 bar condensing.static evaperators 30m of 3/4 pipe.can anyone help. Paul
    Feb 2009
    Australia
    272
    Re: bock f3 24 clutch
    paulc81,
    Your 6''clutch is too small for the F3.
    Bock specifies a 210mm pulley with 2 A section belts for speeds between 960 and 1800 rpm.
    You need a larger pulley.
    Lawrie
    Feb 2009
    Australia
    272
    With the F2 compressor, Bock recommends a 165mm 2A Section pulley.
    Your supplier is not telling you the truth.
  1. Bock FKX-40 COMPRESSOR
    By kelvin278 in forum Transport
    Last Post: 17-03-2010, 10:14 PM
  2. car compressor without clutch
    By milton in forum Transport
    Last Post: 28-09-2007, 05:29 PM
  3. Compressor clutch problem
    By Colin Stamp in forum Trouble Shooting
    Last Post: 09-09-2007, 10:40 PM
  4. Hot wire auto AC clutch to be on all the time
    By frankiee in forum Fundamentals
    Last Post: 16-08-2007, 05:44 AM
  5. Bock AM5 compressor's shaft seal failiure
    By Gareth in forum Trouble Shooting
    Last Post: 05-04-2004, 09:12 PM
