Results 1 to 2 of 2
    Pam G's Avatar
    Pam G Guest
    Replacing water filter on Daewoo fridge/freezer.
    Please can anyone tell me, how to change a water filter on a Daewoo fridge/freezer with water dispenser. I have looked at the connections each end of the filter and dont know if they screw off or are just pulled off to reconnect the new water filter. Also how do you release the pressure before disconnecting the connections?
    Somerset
    69
    4,698
    Re: Replacing water filter on Daewoo fridge/freezer.
    Assuming yours is the same as mine?
    Follow the white tube away from the fridge to where it is connected to the water supply.
    Turn off the tap, (Draw off some water from dispencer this will confirm water isolation) return to the filter.
    To remove either end gently pinch across the pipe.
    At the same time press in to wards the filter.
    When you press in the plastic ring it will release the filters grip on the plastic pipe.
    So push in to wards the filter and at the same time pull the filter and pipe apart.
    Bingo!
    To refit a new filter,just push the plastic pipe into the filter.
    Give them a gentle tug just to confirm they are locked together.
    Cheers Grizzly
  1. daewoo frs2032ibe water leak
    By fitzferret in forum Trouble Shooting
    Last Post: 04-07-2010, 11:17 AM
  2. pure water from air
    Last Post: 26-02-2009, 12:25 PM
  3. Replies: 2
    Last Post: 12-10-2008, 09:41 AM
  4. Comments on this please
    By Robearbam in forum Fundamentals
    Last Post: 18-04-2005, 05:20 PM
  5. Building a wine cabinet
