    Feb 2007
    SIDE OF THE ROAD
    262
    expansion valve with MOP
    hi
    i am having an intermitting prob with the circuit on a tecnair downflow!!!
    every couple of weeks the evaporator ices up restricting flow causing high room tev,when i arrive to site the tev main boby is iced up also.
    the external equalise line is frosted a little near the compressor side but nothing towards tev.
    i noticed from previous threads that the power head must be warmer than the bulb to prevent mop..
    this is a comms room with a 20 degree setpoint!!!
    is there a good way to test these, as when a normal tev goes, it goes!!
    i am thinking moisture also..
    any thoughts ??
    rgrds p
    Somerset
    69
    4,698
    Re: expansion valve with MOP
    Hi Phil.
    Just out of interest, what make TEV is it you have?
    I have seen Danfoss ones where the "O" ring on the orifice cage is passing and causing the External Balance line to freeze up.
    When that occurs we normally just change the orifice assy!
    Mar 2006
    Merate (LC) - Italy
    2,549
    Sorry, can you please explain once again where is the external equalisation? Surely it shouldn't be where you said it is.
    Secondly, can you please inform us about the pressure and temperatures, including superheating and subcooling?
    May 2008
    Malta
    68
    67
    A TXV valve with Mop means that the bulb instead of being liquid filled contains only a small amount of liquid limiting the amount of force that the diaphragm can exert being used to limit compressor load, so as you have rightly said the liquid can migrate to the diaphragm if it gets too cold causing the valve to close.What I would suggest is that you replace this valve with one without Mop as it is a coms room the load does not have great variations so Mop is not needed.
    Feb 2007
    SIDE OF THE ROAD
    262
    Thanks for replies
    The make I think is Sporlan griz, also the usual restriction symptom of low back pressure with high super heat and high subcool... This is happening on 4 units so it all common with this batch of units!!!
    Equalise line is located at the end of evaporate coil, there is no reason why these systems should go into mop.. Head pressure 19 bar @ liquid 38c... Back pressure as 4 bar with 4 c temp...
    Any thoughts??
  1. Lg mps system ( expansion valve location)
    By hussain2002cab in forum Air Conditioning
    Last Post: 18-03-2010, 10:19 PM
  2. Actual Expansion Valve Process
    By AastroGuru in forum Fundamentals
    Last Post: 03-02-2009, 09:53 AM
  3. Setting of Hand expansion valve
    By Iceehot in forum NH3
    Last Post: 10-09-2008, 01:25 AM
  4. the function of the electronic expansion valve
    By Crystal-426 in forum Fundamentals
    Last Post: 22-06-2008, 12:29 PM
  5. Need Divine Intervention - plugged drier or expansion valve?
    By archibaldtuttle in forum Trouble Shooting
    Last Post: 08-06-2008, 06:52 PM
