13-09-2010, 11:55 AM #1
hotpoint ffm90 not maintaining temp
hi all i am a noob on here
please can someone help as i have tried everything i can think of.
fridge/freezer does not maintain temp freezer around -8 and fridge +5. transfer fan in freezer behind panel at back does not turn (does this start after freezer reaches certain temp?)
things i have tried:
1. removed freezer panel and defrosted checked all vents are not blocked.
2. listened for compressor this is fine and the pipes in freezer start to freeze.
3. turned off for 24 hours restarted
4. checked connections.
5. checked what i believe to be thermal fuse four wires 2 blue 2 brown with a continuity test
any help on this will be much appreciated.
13-09-2010, 12:32 PM #2
Re: hotpoint ffm90 not maintaining temp
need to replace thermistors on this one
13-09-2010, 12:41 PM #3
14-09-2010, 02:10 AM #4
mmm sorry my mistake just double checked the model number you need to change thermal fuse.http://www.partmaster.co.uk/cgi-bin/...0%20thermistor and defrost element,http://www.partmaster.co.uk/cgi-bin/...0%20thermistor
split system reach not maintaining temp
By edubhacr in forum Trouble ShootingReplies: 1Last Post: 10-09-2010, 04:23 AM -
Hotpoint Mistral Displaying wrong temp for freezer
By sme22 in forum DomesticReplies: 2Last Post: 09-06-2010, 05:05 PM -
Hotpoint Mistral Plus - freezer temp intermittantly goes above freezing!
By robinsmh in forum DomesticReplies: 0Last Post: 22-10-2009, 01:31 PM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM -
By Air duster in forum FundamentalsReplies: 10Last Post: 02-04-2008, 08:39 AM
