    Sep 2010
    india
    38
    4
    parameter of 407c refrigerant
    respected sir
    im a ac technician and now working on daikin air conditioning system that is roof top units with 25 TR capacity ,,,,but what im facing a problem is the suction line getting ice with 45 psi,,,and exactly do not know the parameter of 407c refrigerant please help me out to solve this problem i need the information for actual suction and discharge pressure,,,,please reply fast
    Split Croatia
    6,151
    Re: parameter of 407c refrigerant
    Suction and discharge pressure depend on temperature of air which passing to heat exchangers, their construction, their cleanliness, amount of air, amount of humidity of air, cleanliness of filters, etc....
    Go here first:
    http://www.refrigeration-engineer.co...ad.php?t=19701
    Mar 2009
    KZN, South Africa
    64
    2,212
    You may want to download & run Coolpack 1.49.
    http://www.ipu.dk/English/IPU-Manufa.../CoolPack.aspx
    This will provide property information for R-407c.
    May 2008
    Malta
    68
    67
    This is definitely not a normal condition and your suction pressure is too low how low depends on the temperature where the indoor unit is,and you should inspect its condition if the coil is icing up and reducing airflow you have a shortage of gas.I suspect that you have little or no experience with refrigeration as these are basic procedures so I wouldn't bother with the Ph chart first concentrate on the basics.
  1. Superheat and Subcooling
  2. Leak Testing?
    By Thana in forum Trouble Shooting
    Last Post: 31-08-2010, 02:57 PM
  3. CARE refigerants by BOC
    By dogma in forum Refrigerants
    Last Post: 23-03-2010, 12:39 PM
  4. MHI FDCA400HKXRE4 Tech Info Please
    By L.JT in forum Trouble Shooting
    Last Post: 23-08-2008, 11:00 PM
  5. fun quiz
    By Brian23 in forum New to RE
    Last Post: 02-10-2007, 10:18 PM
