Results 1 to 8 of 8
    Apr 2010
    China
    7
    Question difference between flooded & liquid overfeed system????
    anyone pls tell the difference between the two systems//
    thx !!
    i confuse them all the time..
    Auckland
    74
    3,357
    37
    Re: difference between flooded & liquid overfeed system????
    same same, just technical terminology.
    Jan 2006
    Adelaide , Australia
    192
    Just check the capillary diameter is correct for the capacity of the systems compressor ( most wholesalers have this info in there catalogs or find on the web ) , then you can get the gas charge right , remember best to charge without the fans running if it has any fans. http://www.actrol.com.au/techPapers/...nHelpGuide.pdf
    60% of the time it works everytime.
    lebanon
    130
    hi
    flooded system meant that the refrigerant is fed from down to up
    over feeding is not a system just too much refrigerant in any system
    Jul 2006
    73
    865
    26
    Quote Originally Posted by barry.feng View Post
    IF you are speaking of Industrial systems the difference is simple.
    A flooded system uses a accumulator mounted above the evaporator. One leg supplies liquid to the evap and the other returns gas and liquid.
    The other is the liquid overfeed. This uses a pump to insure that the coil is flooded. A common practice is to pump 3-4 times more liquid than is evaporated. This is why it is called overfeed.
    Please remember that this is the terminology in my part of the world. Other areas may well use other descriptions.
    Apr 2010
    China
    7
    NH3LVR, thx a lot!!!
    I got the words "overfeed"&"flooded" from ASHRAE Refrigeration..
    i understand it according to ur explanation...
    Apr 2010
    China
    7
    Quote Originally Posted by tonyelian View Post
    hi
    thx very much, tonyelian!!!
    Somerset
    69
    4,698
    Very good post.
    Thanks Grizzly
  1. Superheat and Subcooling
    By Chunk in forum Fundamentals
    Last Post: 15-01-2011, 01:24 AM
  2. Leak Testing?
    By Thana in forum Trouble Shooting
    Last Post: 31-08-2010, 02:57 PM
  3. System Burn Out Troubleshooting
    By altaf22m in forum Technical Discussions
    Last Post: 07-05-2010, 09:24 AM
  4. liquid not reaching TXVs in old rack system
    By tropicold in forum Supermarket Refrigeration
    Last Post: 02-01-2010, 12:00 AM
  5. Refrigeration system proposal; comments please.
    Last Post: 01-01-2003, 03:42 PM
