Thread: Thermocouples.
    Dec 2004
    Australia
    52
    519
    Question Thermocouples.
    Hello all.
    Just wondering what everyone uses for measuring pipe temps for super heat/sub cool measurements.
    I use the K type thermocouple that comes supplied with my Fieldpiece meter and tape it to the pipe with electrical tape.
    Was thinking of buying a pipe clamp thermocouple. They are quite expensive are they really worth it?
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Thermocouples.
    I use an electronic thermometer with two K type thermocouples.
    Can easily see the difference.
    I use a copper stripe like the one that hold the phial of the TXV,
    leaves my hands free.
    Chemi
    Aug 2004
    Holland
    55
    Re: Thermocouples.
    We do use a fluke 2 channel meter with memory for highest en lowest reading (good for checking thermostat difference)
    Got 2 K type wire sensors. these sensors give a extreem quick reaction
    1 k type airprobe
    1 k type surface probe
    2 k type pipe klamps.
    The pipe clamps are used very often for checking expansionvalve overheat, discharge temps, suction temps.
    I also posses a infrared probe, I do not tend to use is very often because it is affected bij product color, light etc, I do tend to use it when working on packs to check the temp of the compressor heads.
    The actual reading is not imporant, but it gives a fair indication if there are broken or bad sealing valves in the compressor.
    Victor
    Apr 2005
    INDIA
    63
    84
    Re: Thermocouples.
    Mr, TEMP-
    I got one k and one j sensor thermometer both are equaly good and cheap compared with PT100 sensor thermometer . one digitial thermometer got 6 selector points with 6 k type thermocouple wire are conected which can be
    sticked with gumed tape to the pipe or surface to check 6 points off the chambers all the thermocouples are of twisted wire type.
    beni joseph
    May 2005
    Australia
    83
    63
    Re: Thermocouples.
    We have 20 Fluke 54 dual input digital thermometers with K type probes that are for our student to use in their training. I also have a touch probe and an infrared that I use to check their work.
    100% is possible 100% of the time
    Apr 2001
    2,099
    27
    Re: Thermocouples.
    Is it possible to see some pics of the equipment , if u have a digital camera handy
    Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
    Dec 2004
    Australia
    52
    519
    Re: Thermocouples.
    Here you go Aiyub.
    I was looking at the dual temperature head which will fit my meter,but it doesnt come with pipe clamp probes.
    www.fieldpiece.com
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Thermocouples.
    Hi Abe,
    Here is the Fluke, good choice.
    Chemi
    Apr 2001
    2,099
    27
    Re: Thermocouples.
    I definately need one!!! Thx
    Feb 2005
    Australia
    123
    Re: Thermocouples.
    Quote Originally Posted by Temprite
    Temprite stick with your K type thermo's I use them all the time for looking at superheats on things, the clamps are bulky unless you work with large sizes in open spaces what size pipes do you work with? Most of the stuff I am involved in is small ~3/4" max so I keep a packet of 3mmx100mm cable ties in the box with my thermometer.
    When I get to a job I just use a couple of ties on each thermocouple to attach it to the pipe. One right next to the bead and another about 1/4" down the thermocouple wire to stop it moving around. If I am worried about airflow influencing my readings a bit of 3mm foam tape stuck over it helps.
    I also found a good bit of info on the fieldpiece website somewhere once. It suggests stripping about 3/4" of insulation from the thermocouple to get more metal in contact with the pipe and speeds up the response time.
    http://www.fieldpiece.com/tech-artic...emperature.htm
    Cheers oz
    Dec 2004
    Australia
    52
    519
    Re: Thermocouples.
    Ozairman.
    I usually work with pipes max 1 1/4".
    Today I made a pipe clamp thermocouple from an old k type bead that I had.Compared it to the method of taping it to the pipe it works just as good.
  1. Capillary Tubes
    By subzero*psia in forum Domestic
    Last Post: 26-06-2001, 11:56 PM
