11-09-2010, 02:04 AM #1
Dual safety relief valves on old York manifold
Hi all. I work in an older plant and have to replace several sets of dual safety relief valves on York manifolds. Rather than the valves being in line with the 'selection' stem of the manifold as in typical dual safety manifolds making it easy to tell which safety valve in in service, these valves are set perpendicular to the stem making it a 50% guess, for me anyway. Has anyone come across dual safeties like this before? If so, when the stem is backed out all the way, which valve is in service, the left or the right?
11-09-2010, 02:37 AM #2
Re: Dual safety relief valves on old York manifold
Here's the information for the valve.
11-09-2010, 02:39 AM #3
this appears to be the same design as a Cyrus Shank valve manifold. It has been years since I have seen one but I believe they are still around. Check "Cyrus Shank" as a search term online. They should have some info for you.
11-09-2010, 10:29 AM #4
Thanks much. Great help.
10-12-2010, 05:28 PM #5
There should be a 1 or 2 on the valve body. If you have the number 1 port on your left. Turn the stem counter clockwise and port 2 should be put in operation, So port one is able to be changed. Then Turn clockwise to put port 1 in operation and port 2 in stand by. Hope this helps...
Pressure relief valves for freezers
By CRH in forum FundamentalsReplies: 3Last Post: 12-02-2010, 08:00 PM -
Relief Valves ???
By VGV in forum NH3Replies: 33Last Post: 07-04-2009, 10:46 PM -
Piping relief valves to atmosphere
By Superheatman in forum IndustrialReplies: 0Last Post: 26-09-2007, 07:30 PM -
Safety valves
By BESC5240 in forum IndustrialReplies: 11Last Post: 06-07-2007, 03:50 PM -
safety valves
By gspatch in forum Technical DiscussionsReplies: 6Last Post: 10-11-2003, 12:36 AM
