Results 1 to 15 of 15
    Jul 2009
    8
    Swimming Pool Heat Pump
    Hi all,
    Can anybody recommend a make of heat pump, for a swimming pool installation ?
    it needs to be about 30kw
    Jan 2009
    NZ
    48
    35
    Re: Swimming Pool Heat Pump
    Mitsi Electric do a city multi, and also Daikin. I'm sure there are a few more.
    Have you got some more specific information?
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by sumsor View Post
    And what that got to do with swimming pools?
    Jan 2009
    NZ
    48
    35
    Well, I assume elex is looking for a hot water heatpump, right?
    Mitsi have a heatexchanger that goes with their city multi system( up to 25kw) and Daikin have their Altherma system.
    Or am I on the wrong track here?
    Mar 2009
    KZN, South Africa
    64
    2,212
    Must be an endless amount of Chinese wannabe heat-pumps available.
    Split Croatia
    57
    6,151
    36
    Well, you are theoretically OK, but financially there is no need for such expensive systems to work on that simple task.
    Also, he probably doesn't plan to heat swimming pool at -15°C ambient.
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by elex View Post
    Hi all,
    Check this:
    http://www.calorex.com/pool-heating/...heat-pumps.htm
    Oct 2008
    newbury
    1,444
    37
    We are a UK repair agent for Nirvana a Canadian HP manufacturer. Pretty good units and the factory is always ready to assist and cover any warranty no questions asked.
    http://www.ambientcontrol.co.uk/content.cfm?cID=201
    Jan 2009
    NZ
    48
    35
    Oh yeah, sorry! I better not dare to post again.
    Oct 2003
    5,630
    34
    The Altherma nor the Mitsubishi can't do this job because they don't have a titanium exchanger. Within a 1 year, the heat exchanger will leak.
    Split Croatia
    57
    6,151
    36
    I don't see a reason for you to be offended.
    Oct 2003
    5,630
    34
    me neither
    nevgee's Avatar
    nevgee is offline Veteran Poster I am starting to push the Mods: of RE
    May 2006
    Yorkshire
    72
    417
    I didn't see if the heat pump was for indoor or outdoor application.
    Heat pumps for indoor swimming pools are designed to handle the ventilation of the pool hall and to maintain a suitable temperature and humidity and air quality. In the process of dehumidification the recovered heat is returned to the pool water or air as required. More sophisticated units also have an air cooling mode where the heat would be rejected to ambient when the pool water temperature is satisfied.
    Outdoor pools usually are heated with an air source heat pump, some can operate in ambients as low as -10C/ -15C
    In all cases the pool water heat exchanger needs to be designed with consideration of the pool chemistry. There is a misconception that pool water with chlorine causes corrosion issues. However, this is not necessarily the case. If the water chemistry is maintained correctly then there should be no problem with corrosion of cupro & copper materials. Usually the main culprit for corriossion issues with pool equipment occurs when the Ph value falls too low, below 7.0 or, there are too many people using the pool without showering, kids cause problems also with organic material being left in the pool, and the free chlorine levels drop below set values. Then Chloramines are created as a byproduct of chlorine and this is very corrosive.
    Reality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
    Mar 2009
    KZN, South Africa
    64
    2,212
    ^ Do not p in the pool.
    Jul 2009
    8
    Many thanks for your replies
  1. Addition of a heat pump to solar heating system
    By rt29781 in forum Heat Pumps
    Last Post: 23-01-2010, 08:46 AM
  2. Alto swimming pool heat pump
    By A2E Services in forum Trouble Shooting
    Last Post: 16-09-2009, 07:45 PM
  3. ned help for calorex swimming heat pump
    By rkmoorthy in forum Technical Discussions
    Last Post: 07-12-2008, 11:54 PM
  4. frostles heat pump
  5. swimming pool heat pump
    By Andy AC in forum The Trail of Tears
    Last Post: 26-08-2007, 04:02 PM
