10-09-2010, 07:17 PM #1
Oil pump explanation of Copeland semi-herm
Does someone have a manual or explanation about the oil pumps, found on Copeland, the systems where the rotation doesn't matter, the oil pumps always the right direction (the swash/swap plate system with the very small stop pin, on the outer non-rotating housing, set out of the middle of the pump)
10-09-2010, 07:27 PM #2
Re: Oil pump explanation of Copeland semi-herm
They are all the same. Frascold uses the same concept. Unfortunately, there is no exploded view available, as far as I know. You may try downloading the spare part electronic catalogue from frascold's website and see if the detail is high enough for you.
You just need the drawing, right. I'm sure you perfectly know how it works, don't you?
10-09-2010, 08:11 PM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Try searching patents.
http://www.wikipatents.com/US-Patent...n-a-compressorLast edited by nike123; 10-09-2010 at 08:13 PM.
10-09-2010, 08:24 PM #4
Sure, I know but I was trying to find drawing or photo's with the different positions in both directions and the intermediate position while changing direction, perhaps some pictures what happens when the stop pin brakes (this is how I discovered years ago how this pump works)
11-09-2010, 04:59 PM #5
Peter,
I've looked through all my Copeland stuff and didn't find any internal diagrams of the pump.
There are plenty of pictures of the oil pump in the AE bulletins and manuals that I'm sure you have.
powellThousands of HVACR manufacturers links! Visit: www.hvacrinfo.com
11-09-2010, 05:03 PM #6
Thansk, this is what I found so far http://www.hvacrinfo.com/cope_ae_bulletins/TAE1166.PDF
liquid ammonia pump calvitation
By Kathleen in forum Trouble ShootingReplies: 23Last Post: 20-05-2011, 02:18 AM -
Help with condensor pump
By Bakerbj in forum Air ConditioningReplies: 23Last Post: 14-06-2009, 12:39 AM -
Water Pump Tripping Overload. (are you sitting comfortably)?
By Grizzly in forum ElectricalReplies: 14Last Post: 27-08-2008, 08:57 PM -
Troubleshooting a vacuum pump and gauge set.
By Old Codger in forum FundamentalsReplies: 7Last Post: 08-08-2008, 05:13 PM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM
