Thread: R22 to Ammonia
09-09-2010, 07:34 AM #1
R22 to Ammonia
Can R-22 compressors be used in Ammonia System. If yes do I need to make some changes?
09-09-2010, 09:15 AM #2
Re: R22 to Ammonia
Yes, If it is an open compressor.
Change all parts/fittings that have cooper on its own composition. Change gauges, pressure controls.
Changing seals is also a good idea. Also change the oil and filters. Maybe change the oil 2 times at minimum is a good idea especially if you can use the oil separator so it would be better cleaned.
Watch out if the same regimen of operating is possible with R717.To make progress is never good enough, I want to do better and better and better
09-09-2010, 10:47 AM #3
Re: R22 to Ammonia
Are you just going to use the compressors or are you thinking of retrofitting the whole plant? Also what brand of compressor are you talking about?
10-09-2010, 04:22 AM #4
10-09-2010, 04:23 AM #5
10-09-2010, 08:50 AM #6
Re: R22 to Ammonia
Check the oil cooler just to be sure. The oil cooler with NH3 for the same regimen needs to release more heat from the oil.
contaminants in ammonia systems
By Johnny Rod in forum RefrigerantsReplies: 29Last Post: 17-10-2011, 05:26 PM -
Want to be trained as an ammonia operator
By Randy Williams in forum NH3Replies: 7Last Post: 26-11-2008, 08:15 PM -
Releasing ammonia into the environment.
By Tycho in forum NH3Replies: 21Last Post: 03-02-2008, 05:10 PM -
Ammonia and CO2 reactor
By gwapa in forum NH3Replies: 18Last Post: 07-01-2007, 04:50 PM -
New Ammonia Certification in United States
By JerrydNH3 in forum NH3Replies: 11Last Post: 15-08-2006, 03:10 PM
