Results 1 to 14 of 14
Thread: For the chiller guys
07-09-2010, 04:51 PM #1
I was looking at an antifrost fault on a MultiClima chiller today. (Just so you know why I had it open)
I don't get much practice on chillers in general, so wanted to ask a couple of general questions on parts of the fridge circuit itself:
a) What is the purpose of liquid injection (controlled by a solenoid valve) into the evaporator just after the TEV?
b) What is the purpose of hot gas 'by-pass' (controlled by a solenoid valve) straight back into the suction line?
This specific chiller has 2 x 3 cylinder recip compressors, 1 on each circuit; each compressor has 2 unloaders. It has 1 common plate evaporator with normal TEV's.
While I'm asking, I have also come across a slightly different setup on a Ciat chiller, where they have the discharge line tee off through a capacity valve and also into the evaporator just after the TEV. What's it for?
Craig
If at first you DO succeed, try to hide your astonishment!!
08-09-2010, 07:55 AM #2
Re: For the chiller guys
1) to avoid excessive suction superheat and it's associated high discharge gas temperature from compressor in extremely low part load condition. It is normally actuated by a temperature probe on the discharge pipe and one thermostat set to 100 or 120°C.
2) If you don't have a condensing control device, and in winter time it can be possible to over-condense or over-subcool, you by pass some hot gas into the suction to reduce the effectiveness of the condenser.
If it was me, from a design point of view I would put the liquid injection straight into the suction, but a liquid slugging would then be possible.Last edited by NoNickName; 08-09-2010 at 07:58 AM.
08-09-2010, 05:06 PM #3
Thanks NoNickname, it's good to understand these additional control features.
They have the hot gas bypass on VRV systems I work on, but the liquid injection after the TEV is a seldom-used concept for me. I have seen some bespoke remote condensing units with excessive pipe-runs where they use liquid injection to keep the compressor cool, and that would be the same concept then. Reducing the non-useful superheat value so the compressor doesn't overheat.
Thanks for your time.If at first you DO succeed, try to hide your astonishment!!
08-09-2010, 06:19 PM #4
Please add to my reputation points.
08-09-2010, 07:01 PM #5
08-09-2010, 07:47 PM #6
Click on the top right corner of the message. There's a scale icon.
09-09-2010, 05:21 PM #7
Multi-clima really are a bag of turd.....dont you think acnerd?
09-09-2010, 10:35 PM #8
09-09-2010, 10:45 PM #9
they are pressure regulators for the evap/plate heat exchanger. it helps getting a steady suction pressure. They also have a slight hot gas by-pass function when the pressure is to high. That is why the evaps are cracking inside diu to thermal shocks, and the water and refrig blend.
Ice
10-09-2010, 04:04 PM #10
10-09-2010, 04:10 PM #11
10-09-2010, 06:47 PM #12
12-09-2010, 07:01 PM #13
i have one now whit a cracked plate evaporator. the fault was a continuously manual reset from the owner. by-passing the LP switch is the most stupid thing you can do.
we have several CIAT chillers in maintenance, and the problems are no different than the other brands.
Ice
23-09-2010, 01:25 PM #14
process chiller help
By talon771 in forum IndustrialReplies: 8Last Post: 12-01-2011, 08:42 PM -
Problems in r22 chiller design
By umeshpradhan in forum Technical DiscussionsReplies: 9Last Post: 06-07-2010, 10:39 AM -
Chiller operation best practice
By Emmett in forum Technical DiscussionsReplies: 1Last Post: 10-03-2010, 08:23 PM -
Absorption Chiller VS Mech. Chiller
By Intern in forum IndustrialReplies: 20Last Post: 30-05-2009, 08:31 AM -
Trane CVHE 450 R11 Centrifugal Chiller
By albertjoseph in forum Air ConditioningReplies: 4Last Post: 06-10-2008, 03:23 PM
