    sholaosho's Avatar
    sholaosho Guest
    york compressor jss.180 and jss183
    dear eng, i work with sheraton nigeria,those chillers are old models. the head pressure is 200psi and the low pressure is about 80psi while it was running it make un usual noise and trips on oil pressure swicth.
    Somerset
    69
    4,698
    Re: york compressor jss.180 and jss183
    Time for a "Service" I would guess?
    Sep 2009
    Cyprus
    64
    110
    15
    What type of compressors there are and when was the last time u have the compressors internally check?
    Sep 2009
    Cyprus
    64
    110
    15
    oh i see u said jss 180 and 183 sorry never heard of that one, maybe u mean js 83 or 84 which mean long or short stroke, and also what style there are A-B-C-D-E F
    Sep 2009
    Cyprus
    64
    110
    15
    CORRECTION i mean 84 0r 83
    pisso81's Avatar
    pisso81 Guest
    dear . how are you ?
    i thank first thing u have o open compressor access cover after storage the charge ( recovery or pumping down ). drain oil . and check mechanical parts and oil stainer . if OK u have to check control side (transducers . micro board . wiring .)
    best regards .
    abbas_hvac@yahoo.com .
