Results 1 to 2 of 2
06-09-2010, 03:52 AM #1
rotary type replacement compressor in place of a piston type unit
Good evening to everyone. I would like to get some opinions in regards to the following situation:
There is this small Trane condensing unit which has its piston type compressor damaged. The almost unreadable data plate model lists a "12", so I suppose it is a 12000 btu unit.
As replacement options, I found both piston type (Copeland, Tecumseh) and rotary type compressors (Hitachi, Sanyo) available, with the rotary type compressors much more economical.
In the past I´ve changed busted piston compressors with scroll units with no noticeable change in capacity. But what about a rotary instead of a piston ? Would it work the same ? I forgot to tell you that the condensing unit is coupled to a fan coil type ducted evaporator.
06-09-2010, 05:37 AM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
mitsibishi unit adresses
By hard at work in forum Trouble ShootingReplies: 2Last Post: 23-06-2010, 06:54 PM -
how the split unit consume less energy then a window type unit
By jahangir.ahmad in forum Air ConditioningReplies: 13Last Post: 27-07-2009, 11:53 PM -
Thermo King OptiSet
By REEFER-TEK in forum TransportReplies: 4Last Post: 06-12-2007, 07:23 PM -
TK basic micro-p features and functions
By REEFER-TEK in forum TransportReplies: 0Last Post: 05-12-2007, 06:25 PM
