Results 1 to 28 of 28
Thread: frostles heat pump
07-02-2006, 02:44 PM #1
Re: frostles heat pump
Air-source heat pumps were being sold in very large quantities many years ago. After the first full year almost everyone I knew who had one complained of cold air blowing during the winter.
I suspect one of the problems is the limited coil surface used on the outside coil. Smaller coils would require lower evaporating temperatures. The lower evaporating temperatures increase the potential for frost formation, which is dependent on the air dewpoint temperature.
If the heat pump was operating at -22C, then this is not that much different than a refrigeration system that is used for a walk-in freezer.
LC, who was the manufacturer of this heat pump?Last edited by US Iceman; 07-02-2006 at 08:24 PM. Reason: text editing
07-02-2006, 08:13 PM #2
Originally Posted by US IcemanIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
New Heat Pump Forum
By Argus in forum Heat PumpsReplies: 17Last Post: 10-04-2010, 09:12 AM -
Attic Heat Pump
By KETTLER in forum Heat PumpsReplies: 35Last Post: 23-02-2008, 11:33 PM -
Homemade Heat pump water heater
By busman in forum Technical DiscussionsReplies: 20Last Post: 05-02-2008, 04:04 PM -
Rebuild air2air heat pump
By stalker in forum Technical SpeculationsReplies: 3Last Post: 02-11-2006, 10:10 AM -
heat pump capacity adjust
By Lc_shi in forum FundamentalsReplies: 5Last Post: 14-02-2006, 07:32 AM
