Results 1 to 9 of 9
    Aug 2010
    usa
    14
    split system charging
    after installing a split system more refrigerant is needed based on the length of the line set. the amount of extra ***** needed to add is based on liquid line size right? does it matter what the suction line size is? for instance the manufacturer states that the condensing unit is charged with 180 oz of refrigerant for up to 15 feet of line set, but if you have a 45 foot line set you have to add ***** for 30 more feet of line set. the liquid line size is 3/8 size and the suction lin size is 3/4 on the system im referring to.
    Jul 2007
    Australia
    1,845
    Re: split system charging
    Are you using the same size tubing that the unit is designed for?
    Is the total length (between the indoor and outdoor, not liquid line length added to suction line length) under the permissable total length stated by the manufacturer?
    If same pipe diameter, if not over the maximum range, the extra charge required as stated by the manufacturer is for the extra difference in distance between the indoor and outdoor units. They already assume suction and liquid lines to be the same length and have factored that into their extra charge required.
    So if you are using the same size piping, then you add ***** for 30 more feet.
    3,856
    Is this a mini split or an American style system to a central ducted air handler?
    Mini split like we get over here and its grams per meter over the pre charged lenght, central air and it can be off a chart, or done with subcooling or superheat depending on the expansion device.
    Split Croatia
    57
    6,151
    36
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by frankman View Post
    No, it does not much.
    Volume of evaporated refrigerant is many times higher than volume of liquid refrigerant.
    For example 1 kg liquid R410 at 4°C bulb point is 0,86 l volume and 10K superheated vapor is 32,3 l.
    Aug 2010
    usa
    14
    i know you add ***** for 30 more feet but how do you know how many ounces to add for the 30 feet.
    Aug 2010
    usa
    14
    this is american style split system heat pump r22 3 ton.
    Split Croatia
    57
    6,151
    36
    Then you charge by superheat table or weight stated in instalation manual.
    Sep 2010
    43
    13
    Correct, the install manual will tell you how many grams per Meter or foot. There are tons of video's out there to help you.
  1. Daikin fault codes
    By Chris2005 in forum Air Conditioning
    Last Post: 21-03-2012, 10:09 PM
  2. Lost Remote Control for Split System AC
    By kiamaian in forum Air Conditioning
    Last Post: 12-04-2009, 06:12 PM
  3. Heating not working on split system what is the problem?
    By airflo in forum Air Conditioning
    Last Post: 22-07-2008, 06:42 PM
  4. Charging system with TEV
    By ahl in forum Commercial
    Last Post: 14-07-2008, 03:53 PM
  5. System charging
    By Dylan in forum Fundamentals
    Last Post: 17-12-2004, 10:37 PM
