    philippines
    8
    temperature problem
    Proper valve operation can be determined by measuring superheat. If too little refrigerant is being fed
    to the evaporator, the superheat will be high; if too much refrigerant is being supplied, the superheat
    will be low. The correct superheat setting is between 10 and 15°F (5.6 and 8.3°C).
    Adjustment
    To adjust the superheat setting, proceed as follows:
    1. Remove the valve cap at the bottom of the valve.
    2. Turn the adjusting stem counterclockwise to lower the superheat.
    3. Turn the adjusting stem clockwise to increase the superheat.
    Just read this article about superheat and i found it confusing regarding the two temperature given can anyone please explain what does it mean. thank you.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: temperature problem
    One is farenheit, the other is celsius centrigrades, which is wrong because temperature differentials should be in kelvins
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by NoNickName View Post
    Not exactly:
    Thermodynamic temperature: kelvin (K)
    The kelvin is 1/273.16 of the thermodynamic temperature of the triple point of water.
    The unit kelvin and its symbol K should be used to express both thermodynamic temperature and an interval or a difference of temperature. In addition to the thermodynamic temperature (symbol T) there is also the Celsius (symbol t) defined by the equation t=T-T0 where T0=273.15 K. Celsius temperature is expressed in degree Celsius (symbol C). The unit 'degree Celsius' is equal to the unit 'kelvin', and a temperature interval or a difference of temperature may also be expressed in degrees Celsius. (The word degree and the sign o must not be used with kelvin or K).
    http://www.gordonengland.co.uk/conversion/sibase.htm
    philippines
    8
    Thumbs up
    thank you very much!
  1. Condensor split temperature
    By Peter_1 in forum Fundamentals
    Last Post: 31-07-2011, 05:49 PM
  2. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  3. Great problem........
    By Bashir01219 in forum Fundamentals
    Last Post: 05-03-2011, 10:56 AM
  4. Thermo King OptiSet
    By REEFER-TEK in forum Transport
    Last Post: 06-12-2007, 07:23 PM
  5. fun quiz
    By Brian23 in forum New to RE
    Last Post: 02-10-2007, 10:18 PM
