    Sep 2010
    7
    Compressor Performance Modelling
    Hi, new to this forum, hoping for a bit of help with some thermodynamics.
    I get involved with various a/c projects occasionally involving custom manufactured compressors. Typically this would involve taking an open automotive scroll or piston compressor and turning it into a semi-hermetic or hermetic. Usually there will also be a change in refrigerant at the same time.
    The problem we have is coming up with a reliable compressor performance prediction. The more usual, simpler, heat loads and system balance calculations are no problem. Prediction of a compressor performance with only very limited initial data is more of a problem and needs a deeper understanding of the thermodynamics internal to the compressor.
    I'm looking for any recommended books/articles/papers which could help.
    Rich
    Nov 2005
    New Zealand
    550
    Re: Compressor Performance Modelling
    My wife used to say you never listen to a word I say at least I think that what she said
    Sep 2010
    7
    Thanks for the link, looks interesting.
    What's this GOOGLE thing?
    Nov 2005
    New Zealand
    550
    Quote Originally Posted by Rich_J View Post
    Go to www.google.com its the best search engine to find things on the net
    http://www.onlinefreeebooks.net/engi...oning-pdf.html
    Mar 2006
    Merate (LC) - Italy
    2,549
    Try www.asercom.org and browse for specs of a very large number of existing compressors. Based on the data published, you would be able to model performance of your compressor.
  1. system modelling
    Last Post: 11-04-2010, 04:39 PM
  2. Water Coil Modelling
    By azzad in forum Tools and Calculators
    Last Post: 28-12-2008, 09:38 PM
  3. Contaminant modelling
    By nh3simman in forum Air Conditioning
    Last Post: 25-04-2007, 07:24 PM
  4. water to water GSHP modelling
    Last Post: 26-05-2006, 06:51 AM
