Thread: ac overload
04-09-2010, 05:17 AM #1
ac overload
I am not a refrigeration mechanic but i am after some advice. Can anyone help me ? I have a small ridig truck that has a fridge van on the back,the fridge van has Thermo King v-250 model 20 refrigeration unit mounted on the front . when in use the unit works well for a while then shuts down and shows ac overload on the cab monitor . Can anyone tell me what may be causing this problem? Thank you kindest regards Wayne.
04-09-2010, 07:21 AM #2
Re: ac overload
The first thing is to check the amp it is pulling and compare to the setting of the OL.
If it is in the range, than you need a fridgy to check the system.
05-09-2010, 07:38 PM #3
Re: ac overload
hi
you have to check dirty condenser and its fan those things can also make the over load trips off
06-09-2010, 06:19 AM #4
Re: ac overload
Most common problem with those units is the bridge rectafier. There may also be issue with the standby motor but with info given, hard to say.
14-09-2010, 08:34 PM #5
Re: ac overload
hi
having worked on a few these i have found that when the motor starts to get worn you can sometimes get away with fitting a delay timer to the compressor clutch.so the clutch engauges after the motor starts.
16-09-2010, 08:55 PM #6
17-09-2010, 10:35 PM #7
Evaporator fans going on overload
By AndyHX in forum Trouble ShootingReplies: 10Last Post: 20-02-2010, 09:21 PM -
Current Overload Trip
By Meer Abdulrehma in forum Trouble ShootingReplies: 7Last Post: 19-10-2009, 03:29 PM -
Water Pump Tripping Overload. (are you sitting comfortably)?
By Grizzly in forum ElectricalReplies: 14Last Post: 27-08-2008, 08:57 PM -
thermal Overload
By marc5180 in forum Trouble ShootingReplies: 51Last Post: 03-11-2007, 10:25 PM -
Overload tripped lesson
By rosliin in forum DomesticReplies: 8Last Post: 26-06-2006, 03:49 AM
