    mshynson's Avatar
    mshynson Guest
    Grunaire F1 error code
    i have two 121-hx units. a few months ago i got a F1 error code on one. replaced the PFC board and problem solved. now i have the same code on the other unit. replaced the PFC but still have the F1 code. all connections look good. any ideas? these units are great when they work......
    mshynson's Avatar
    mshynson Guest
    Re: Grunaire F1 error code
    still broken. any ideas?
    49
    3,874
    Swap board from good unit to one with fault code, if code goes, new board faulty.
    If code stays look for another problem.
    We don't get that make over here, what is an f1 code for?
    dante805's Avatar
    dante805 Guest
    Just got the same code. F1. Did you ever figure it out? Checked all the connections to the unit. Is there a reading or easy way to figure out if its the PCB board? There seems to be 3 boards which one is the PCB? I have a spare unit so can exchange parts pretty easily. Thanks.
    alive2live's Avatar
    alive2live Guest
    F1 usally means the main boards in the outside unit is bad.
    Amcor units were notorious for F1 outside PC board failures. Grunaire is made by the same company.
    alive2live's Avatar
    alive2live Guest
    Meant to say, it is the main pc board in the outside unit that likely burned out.
  1. Grunaire GMU028HXB-4 wiring question???
    By danoseven in forum Technical Discussions
    Last Post: 16-07-2010, 12:25 AM
  2. Grunaire Mini Split Operating PSI
    By drose300 in forum Technical Discussions
    Last Post: 09-07-2010, 05:31 PM
  3. Grunaire Mini-split
    By kevperro in forum Heat Pumps
    Last Post: 07-07-2010, 10:26 PM
  4. Grunaire HX 19 Seer mini split
    By Sturgis in forum Trouble Shooting
    Last Post: 29-06-2010, 10:58 PM
  5. grunaire hx inverter mini split
    By oatelek in forum Trouble Shooting
    Last Post: 26-01-2010, 12:38 AM
