02-09-2010, 01:01 AM #1
Pipe insulation breakdown large NH3 plant
Has anyone out there have information or articles on heat load imposed on refrig plant due to deteriorated lagging .
Client trying to justify replacement of lagging ( old polystyrene type ) to management .
System has -40 C & -10 C liquid overfeed system with long piperuns in ceiling & outside ( -40 outside ) .
System is installed in tropical climate which is my immiediate concern.
Thanks in advance
02-09-2010, 11:45 AM #2
Re: Pipe insulation breakdown large NH3 plant
I can't offer any advice on calculating the heat load imposed by bad insulation but there may well be a regulatory cost associated with it.
Take a look at some OSHA citations on the matter at: http://taocompliance.com/news/?p=30
You may be able to justify it as a cost-avoidance issue.
02-09-2010, 02:53 PM #3
Try this program to calculate heat gain. http://www.pipeinsulation.org/. Failed or wet polystyrene can probably be calculated as 0 insulation. The larger risk is a major leak when (not if .. when) there is a pipe failure from corrosion.
02-09-2010, 04:01 PM #4
And if the insulation gets liquid water or vapor water from atmosphere it will condense and solidify expanding because of the "hydrogen bridges" and ....bumm...
Pipe diameter, real life and theory
By gwm121 in forum FundamentalsReplies: 8Last Post: 24-10-2009, 04:53 PM -
Measurement of pipe lengths
By batfink in forum Technical DiscussionsReplies: 11Last Post: 23-09-2008, 09:50 PM -
Burst Pipe caused by Abrasion. (aka Only on a Friday)
By Grizzly in forum Chit Chat & Service StoriesReplies: 11Last Post: 19-09-2008, 06:59 PM -
pipe insulation thickness
By bangoman in forum Air ConditioningReplies: 3Last Post: 24-04-2008, 08:43 PM -
large refrigeration plant cooling tower issue
By Lc_shi in forum New TechnologiesReplies: 4Last Post: 25-03-2007, 01:35 PM
