Results 1 to 2 of 2
Thread: Gram plus freezer
31-08-2010, 09:57 PM #1
Gram plus freezer
Hello guys, have any of you got a service manual/programming guide for one of these freezers? If not, does any body know if you can force a defrost? The one I am looking at has a locked controller.
Andy
02-09-2010, 04:16 PM #2
Re: Gram plus freezer
Hi Andy
You can only trigger an automatic defrost by switching the cabinet off and back on when it is down to temp.
This will then give you chance to monitor the defrost through the full 30 minute cycle.
Can you confirm the cabinet model and serial number?
I will then be able to PM one over.
Sturt.Last edited by Sturt; 02-09-2010 at 04:24 PM.
Maytag Freezer TOO Cold (and fridge also)
By ptb626 in forum DomesticReplies: 1Last Post: 17-08-2010, 01:56 PM -
Blast Freezer Within Freezer
By rickmor in forum Technical DiscussionsReplies: 4Last Post: 18-06-2009, 03:37 AM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM -
Gram freezer problem
By dunny123 in forum Trouble ShootingReplies: 3Last Post: 07-07-2008, 10:55 PM -
Gram plus F660 L freezer
By wallwall in forum Technical SpeculationsReplies: 7Last Post: 08-08-2006, 04:52 AM
