Thread: LG CV-H246BLBO problem
20-06-2005, 08:23 PM #1
Hi all,
Went to look at this ceiling mounted unit tonight and found when the controller is pointed at the unit and switched either on or off, the same thing happens.
louvers vibrate as they try to close further, even though they are already closed, for about 5 - 10 seconds. Also the power light(red) glows for about half a second and the unit then does nothing else. It seems like the unit wants to shut down no matter what. Switching power off and on had no effect.
I have read previous posts with similar problems, although not the same, I think it needs a new pcb.
System is only a couple of months old.
Any comments?
20-06-2005, 10:26 PM #2
Re: LG CV-H246BLBO problem
Seems to me that LG are still not a reliable unit yet.
20-06-2005, 11:13 PM #3
Suggest you check the door switches. If door is hanging just enough to open switches the unit will not start. Door switches turn unit of so no harm when changing filter or plasma.
Make sure both switches pushed up and fire remote to see if unit starts.
Marc could be right but check switches first.
York Screw Oil Problem
By tomt in forum Technical DiscussionsReplies: 10Last Post: 02-12-2009, 02:48 PM -
what's the problem
By botrous in forum Air ConditioningReplies: 35Last Post: 22-06-2008, 02:54 AM -
Strange problem
By Peter_1 in forum ElectricalReplies: 9Last Post: 10-04-2007, 05:19 PM -
Condensation Problem At Door to Freezers
By mmarch in forum Air ConditioningReplies: 5Last Post: 17-10-2005, 02:42 PM -
Problem with centrif - help requested
By Brian_UK in forum Industrial CompressorsReplies: 5Last Post: 03-08-2005, 10:31 PM
