Results 1 to 9 of 9
    Worrped's Avatar
    Worrped Guest
    Charging AC in extreme temps
    I was wondering if their is anyway to charge a system after an install in a house that is now upper 90degrees, We have been in the attic putting in new system so all the heat is pulled down into the house. My real question is I don't want to have to return another day to recharge the system after it has cooled down. Can I charge it properly in 90 degree house temps? Thanks
    May 2008
    66
    802
    Re: Charging AC in extreme temps
    it is difficult, but it can be done. just make sure the calculations are wright.
    Ice
    Oct 2003
    5,630
    34
    Isn't there a nameplate with the weight?
    I see a lot more problems when charging in winter where one tries to fill till its HP is high enough.
    Is he unit capillary fed , TEV or EEV?
    Fill till you have 10 K to 15 K superheat once the houses cools down to its normal summer setpoint.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Yeah. More problems in getting the high pressure high in winter.
    I don't see a problem in charging in a 90F environment.
    lebanon
    130
    hi
    u can charge it with ampermeter &gauges until the desired temperature
    Oct 2003
    5,630
    34
    Charging with AMP meter is a very bad practice.
    Where will you get the correct AMP's?
    Mar 2006
    Merate (LC) - Italy
    2,549
    Quote Originally Posted by tonyelian View Post
    hi
    lebanon
    130
    hi peter 1
    when the room reaches the desired temperature its not ideal but there is a limit we cant go beyond of course when its hot it pulls more amp&when its cold it pulls less any way most of ac have a plate &the weight of gas on it
    i did not say thats ideal but it helps to be near the right way to do the job when there is lack of information
    Split Croatia
    57
    6,151
    36
  1. Compressor oil temps
    By Superfridge in forum Industrial Compressors
    Last Post: 17-11-2009, 08:35 PM
  2. Why is suction gauge reading retard during charging?
    By acrefconsultant in forum Technical Discussions
    Last Post: 27-09-2009, 08:57 PM
  3. Cold weather charging
    By FEISTY in forum Tools and Calculators
    Last Post: 27-02-2009, 08:14 AM
  4. HELP with charging
    By damo1206 in forum Refrigerants
    Last Post: 27-11-2008, 12:37 AM
  5. Extra Horsepower From Cooling Intake Temps
    By BigJon3475 in forum Technical Speculations
    Last Post: 12-07-2007, 01:37 AM
