Results 1 to 1 of 1
28-08-2010, 02:49 PM #1
multi-user cooling system on a ship
We build equipment for analysing seabed samples on board ships. We have a variety of demands for "coolth" including:
Seawater ice
Seawater at any temperature between 1-10°C
Cold air for a reefer-type container at any temperature between 1-10°C
Small capacity freezer units at @ -20°C
Airconditioning units for 20' containerised laboratories
We have started looking at running our units on ships with zoned areas that require HVAC specs including Explosion Proof motors etc. Such systems are VERY expensive so we were wondering about running a special unit (maybe in a 10' container) with several compressors and evap units and piping either glycol mixes or simply cold water to sites around the ship where "coolth" is needed. This way we cut down on the need for EX-rated fan units, and if we design it well will have redundancy in the system to protect against failures.
Is it sensible/possible to view "coolth" in the same way as say electricity and have a unit into which you could plug a variety of users for a variety of uses/services? Reliability is extremely important to us so we would want dual systems etc.
kindly suggest cooling system for refrugerated water circulator
By mittalakhil in forum Industrial CompressorsReplies: 0Last Post: 11-05-2010, 07:58 PM -
3 single split units or one multi split - consumer advice needed
By kok in forum Air ConditioningReplies: 18Last Post: 15-04-2009, 08:42 PM -
AHU Integral Cooling System
By CoolKids in forum Air ConditioningReplies: 2Last Post: 19-11-2008, 08:23 PM -
LG Multi V plus System - Service manual
By lucklife in forum Air ConditioningReplies: 2Last Post: 18-11-2008, 10:47 AM -
new to RE - want to analyze low pressure R134a cooling system
By hcoles in forum New to REReplies: 3Last Post: 09-11-2008, 05:24 PM
