Results 1 to 9 of 9
Thread: walk in freezer smokey
26-08-2010, 04:11 PM #1
hey guys had another enquiry by a chef he says his walk in freezer builds up with wat appears to be smoke further too this blows out a funny smell iv checked the coils no ice build up i cant see signs of anything burnt its on an auto defrost cycle twice a day could this have anything to do with it any ideas let me no im pickling my brain over this
26-08-2010, 04:29 PM #2
Re: walk in freezer smokey
Doe's he smoke inside the freezer?
Usually the fans stop running when you open the door, could any of them is on its way and the smell is of burned winding insulation?
You did not mention the type of defrost, could something touches the heating elements? [If there are any]
26-08-2010, 04:53 PM #3
hi andy, if there is smoke in the freezer , turn it off and get it cheaked out, usually its frost haze, nothing to wory about, sedgy,
26-08-2010, 05:06 PM #4
lol i dnt think he having a quik puff in the freezer but il ask,frost haze probably best bet ,but il defo check the heating elements out, what did u mean by winding insulation?
26-08-2010, 06:04 PM #5
THE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
27-08-2010, 02:21 AM #6
increase drain time after defrost and fan delay is probably to short
29-08-2010, 06:27 PM #7
If chef goes in towards the end of a defrost - perfectly normal experience.
12-09-2010, 02:03 AM #8
Nah man I had this the other day couldn't see anything at first , its the fan delay klixon on the end of the coil ( 3 wire job ) its cooking internally
60% of the time it works everytime.
12-09-2010, 03:48 AM #9
If it is not a bad fan motor.........I hade one SMOKE last week; but you can smell that a MILE away!
a bad fan termination switch during defrost could cause the fans to run while the heaters are fired and would throw a MIST in the air.
Defrost cuts the fans and fires the heaters, then the other sensor senses that the coil is icing and then it turns the fans back on to ensure water wont be misted all over the box.
Check that out and maybe that could be it.
Modifying/troubleshooting Porkka walk in freezer
By cyberkul in forum Technical DiscussionsReplies: 10Last Post: 18-11-2010, 06:59 PM -
walk in freezer wont drop under 20 degrees
By Deniver45 in forum Trouble ShootingReplies: 11Last Post: 31-08-2010, 09:41 PM -
Water is leaking into my walk in commercial freezer! Need help!
By atadi in forum Trouble ShootingReplies: 5Last Post: 06-08-2010, 10:53 PM -
walk in freezer refrigeration sizing?
By trammd in forum Technical DiscussionsReplies: 10Last Post: 02-11-2006, 11:56 AM -
It's snowing in my walk in freezer!
By Matt in forum CommercialReplies: 19Last Post: 14-10-2006, 07:07 AM
